To much?
Can someone tell me hppw to change a EGR valve? or hpw to check it WHERE to find it or something
i removed that big *** thing that says 4.6
and dont know where the EGR valve is or nething, im lost.
So can someone help me and give me a rund down on where to find this EGR valve and how to check the gasket or clean it?
PLEASE
PLEASE
I would recommend a repair manual before you go tearing into your engine. It will list the proper removal procedure, the needed tools, and torque values for the remove and replace. Chilton or Haines would both be a good stating point and you can get them relatively cheap at any decent parts house. It will help you build experience with minimal costly and embarrassing mistakes.
Your 4.6 is an extremely reliable engine. With proper maintenance that engine will run for a long time.
