Rubber Valve Cover Gasket
Old Oct 20, 2003 | 08:25 PM
mdstud's Avatar
Hmm anyone know where to get a rubber valve cover gasket? as opposed to the Cork, I can't get the cork ones to seal right... I even used rtv on one set and it still didnt seal... Thanks guys for any suggestions.
Old Oct 20, 2003 | 09:35 PM
Neal's Avatar
Cool
HI!... Theres a company called DETROIT GASKET that makes a one piece solid rubber valve cover gasket. I have a set on my 351W (408C.I). They seal really well. If you have stamped steel (chrome) valve covers then make sure they are *SQUARE* on the gasket sealing surface. Or you can also use *SPREADERS* which are long steel tabs that fit under the valve cover bolts and help spread the bolt pressure across a wider surface of the valve cover flange.
Old Oct 22, 2003 | 12:34 AM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
I use permatex black form a gasket sealant on the cork gaskets, never had a leak to speak of. I've tried once or twice to use the silicone stuff, and it always makes the gaskets squeeze out everywhere. The black permatex stuff seals like a vault, hehe,,,,98
The black permatex is the number 2, unless I'm mistaken. Use it, you will be surprised
Old Oct 22, 2003 | 12:37 AM
98SCREAMER's Avatar
I say black, but it really looks like a dark olive green, Just to help stop any confusion before it starts, hehe.,,,98
