Chirping /Squealing
Old Oct 16, 2003 | 02:49 PM
PitbulI's Avatar
Chirping /Squealing
Just replaced the Serpentine belt on the 1997 Ford f-150 4x4 4.6 Litre.
Before It was done today, Since it's cold here in Canada, it was just chirping its @$$ off all the time, and different pitches and sounds of chirp.
After it was replaced with a gatorback belt the chirping/squealing sound has lessened but is still there. What else could this be ?
Thanks.
Old Oct 17, 2003 | 02:46 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Could be the belt tensioner,powersteering pump,altenator....
try spraying a little wd inside the belt tensioner and see if it helps. maybe even a little belt dressing on the new belt may help. good luck...
Old Oct 17, 2003 | 06:38 AM
B-Man's Avatar
Cool
I wouldn't spray WD-40 on anything that needs lubrication, except maybe a closet door hinge. It's lubricating properties are short-lived at best.
If you are going to spray something into the tensioner, try using something like Tri-Flow, etc.
Just my $.02...
Old Oct 17, 2003 | 12:17 PM
tkarter's Avatar
Chirping would be in my opinion caused by a weak tensoner or something that is too tight and about to lock up. Usually would make sure to check the power steering pump.
tom
Old Oct 17, 2003 | 01:19 PM
Pestco1's Avatar
was there any rubber residue on the pullies beofre you put o the new belt. Sometimes the old belt will leave a rubber film on the pullies and causes noise with a new belt. the other suggestions about the tensioner are also worth checking out.
Old Oct 17, 2003 | 08:36 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Wow, that's the first truck I've heard of that wasn't helped by a Gatorback? Mine squealed off and on for two years and three belts(2 tensioners). It stopped cold the second the gator was on.,,,,98
