New Engine???
Old Oct 14, 2003 | 10:05 PM
ALVAR's Avatar
Unhappy New Engine???
HI, I HOPE YOU ALL CAN HELP ME WITH THIS, I GOT A F-150 X CAB WITH 165.000 MILES, AND THE ENGINE HAS A NOISE VERY SIMILAR TO THE DIESEL ENGINES BUT SMOOTHER.
WHAT COULD IT BE?
THANKS
Old Oct 15, 2003 | 08:11 AM
mikemike98's Avatar
It may be a crank bearing starting to go , a broken valve spring or some piston slap. Try putting a screwdriver to different parts of the engine to find out where the noise is the loudest and maybe check the plugs and compession to startwith.
Does the noise get louder or change pitch when you're driving?
Did it start all of sudden?
Are you lossing power?
Old Oct 15, 2003 | 11:20 AM
Green_98's Avatar
the 4.6's have a "dieseling" sound at times i think it is heard most when the truck is idling. Have a mechanic listen to it....if its running right, keep on driving!
Old Oct 15, 2003 | 10:09 PM
ALVAR's Avatar
the sound it's always the same, it doesn't get louder.
i don't losse any power and the noise started of sudden.
im gonna try to find out where te noise is coming from.
thanks guys.
