Amsoil air fiter questions!!!
Old Oct 11, 2003 | 12:48 PM
sean46's Avatar
I saw something a while back about an air filter made by amsoil that was comparable to the K&N air filter. I think it was also supposed to be high flow. I looked on the Amsoil site but it difficult to find out what vehicles they fit. Does anyone know if they make a high flow air filter for a 2001 F-150 with a 4.6 V8? Any info about it and how I could get one would be great.
Thanks, Sean
Old Oct 11, 2003 | 03:39 PM
msparks's Avatar
They just come out with the "cone" design. We've been asking for them since 1997. Amsoil revamped their filter line now call it: Flowzair with a better frame material and sealing material. It still used the same type of 2 stage Foam media with the high tack oil.
Here is the reply from my question to Amsoi tech services:
Yes, for all applications where the Hastings AF484 cone type filter is used, the new Flowzair TS191 is now available.
Thank You,
Jim Van
AMSOIL Technical Services
Hope this helps
msparks@lube-direct.com
Old Oct 11, 2003 | 08:35 PM
sean46's Avatar
Thanks Msparks
Would this work with a cold air intake like say a K&N tube or Air Force One or something like that. I want to get a cold air intake but I am a little hesitant about using a K&N Fiter as I have heard and seen some bad results with dirt getting by. One other thing. How do I go about purchasing a filter?
Thanks, Sean
Old Oct 11, 2003 | 10:11 PM
msparks's Avatar
Originally posted by sean46
Thanks Msparks
Thanks, Sean
This is a stock replacement filter only, it won't work with any special setup at this time.
As far as purchasing, it would be best to contact an Amsoil dealer for pricing and so forth.
