04 5.4 Track times
Old Oct 10, 2003 | 03:28 AM
Bottlefed306's Avatar
04 5.4 Track times
I know its early but id like to know what these things are running. And can you get a reg. cab short bed still with the 5.4.
Old Oct 10, 2003 | 07:20 AM
APT's Avatar
APT
Yes, you can still get that configuration. I don't know that anyone one here has bought a regular cab, but they'll show up. I expect 1/4 mile in the 16 flat second range.
Old Oct 10, 2003 | 12:32 PM
suzukidragracer's Avatar
I would expect it to run a bit faster than that.
My 2002 5.4 SCrew, completely stock, went 16.29 @ 82 mph, at a slow track.
On the bike in St. Louis, I'm used to going about .15 seconds quicker than at home.
The '04 has more power, but is heavier than the 02' also.
It may get down to about 15.8 with the short bed 2wd, a solid launch, and a good track.
by the way, the 60' on that run was a 2.30.
~Vince~
Old Oct 10, 2003 | 03:38 PM
03F15054FX4's Avatar
My 03 F150 ran a 16.4 @ 86mph.
This is a supercab, 4x4 5.4L 3:55 gears.
I bet a reg cab short bed 04 5.4 will run 15's, should be low 15's.
Old Oct 12, 2003 | 05:58 PM
jstang's Avatar
I've gone 16.0@91 mph with a 4.6 and 3:08's. It weighs 4760. 01 X-Cab 4X2. The new truck is heavier by 300 pounds I believe, every 100 pounds is a .10 sec, or 10 horsepower on a 3000 pound vehicle.
www.corral.net has Hp and 1/4 mile calculators, I'm sure you could go there and plug in some numbers and get an esimate.
Old Oct 12, 2003 | 06:44 PM
Intel486's Avatar
Originally posted by jstang
I've gone 16.0@91 mph with a 4.6 and 3:08's. It weighs 4760. 01 X-Cab 4X2. .
I've got to be overlooking something here... do you have any mods on that truck? What were the weather conditions?
My truck setup is a
2000 F-150 Extended Cab 4x2 w/ the 4.6l engine. When I race it I don't do any weight reduction. I keep the trailer hitch, Tailgate, and Snugtop bedcover on.
My Best times with 3.08 gears, Superchip, and no muffler was a 17.4 @ 80...
I've now got Electric Fans, Magnaflow Cat-back, Underdrive Pulleys, K&N FIPK, Superchip, and 3.73 Limited Slip. The best time I've run with this setup is a 16.55 @ 82. The weather was around 70 degrees and decent humidity.
Old Oct 13, 2003 | 08:06 AM
'90 SSC Clone's Avatar
I just recently went to the track at Gateway International Raceway in St. Louis with a '04 Screw 4X4 with the new 5.4L. Went 16.78 @ 81.1 mph with a 2.4 60ft. The truck has 900 miles on it with no MODS. I didn't really think that this was too bad, considering how big this truck is!
Old Oct 13, 2003 | 11:36 AM
just_right's Avatar
Intel486
I'm with you on this one. I've never seen a stock extended cab truck with the small V8 and 3.08 gears come remotely close to a 16.0 et.....and especially at 90mph. I don't care where you run at or what temperature it is, nobody will run that in this trucks package. Now if the truck is moderatly modded, then a 16.0 et is reasonable....but not the 90mph. In rough terms, to run 90 mph in the 1/4 would translate to about a 15.0 et. Just my 2cents worth.
Old Oct 13, 2003 | 02:06 PM
Intel486's Avatar
just_right, I noticed that the speed and time also don't really match up. Maybe he typed something in wrong... or waits until half track to start spraying a 250 shot or something...
