Conflicting Codes
Old Oct 9, 2003 | 04:19 PM
gwmt's Avatar
Conflicting Codes
My Check Engine Light has been illuminated, I've brought it in for service and the error codes are: PO172, PO174, PO171, PO175 which say the fuel/air ratio is too lean and too rich. Any ideas what would cause this? Everything else has been working fine except I have noticed the rough idle other users have noted. Any help would be appreciated. Thanks.
Old Oct 9, 2003 | 04:25 PM
tkarter's Avatar
The way I read your codes would mean that the left side is lean the right side is rich.
I would reset the PCM go for the second reading and if the same would replace the left side O2 sensors.
tom
Old Oct 13, 2003 | 01:34 PM
projectSHO89's Avatar
Dead or very weak O2 sensors will cause conflicting codes.
Replace the O2 sensor(s), reset the codes, and see waht happens.. Your problem will likely be fixed.
Steve
