Any advice for Header install?
Old Sep 29, 2003 | 11:10 AM
WLF's Avatar
WLF
Thanks OLDGRAY.
Do you remember the torque speck for these bolts?
Called JBA today and they are going to send me out the header bolts. I should be able to install by sat. I am suppose to get the transmission installed on friday so by the end of the weekend I should be set...
Old Sep 29, 2003 | 05:49 PM
GearHead_1's Avatar
Re: hedder bbolts
Originally posted by OLDGRAY
I did not remove the starter. You can figure about 10 hours labor to do this. Like I said let the rusted on nuts take out the studs for you.Its a step you wont have to do...One thing I forgot is to remove the EGR line first ok..good luck oldgray
10 hours??? I think you should have removed the starter. Seriously this took less than 3 hours. Mine only had about 12,000 on it when I did this but it wasn't nearly this hard.
Old Sep 30, 2003 | 05:24 PM
OLDGRAY's Avatar
time limit
Hi gearhead. If you figure the time it took to jack up the truck,remove the wheels, remove the inner panel,it takes some time to do all this,also I had to cut off the exhaust pipe bolts .Tell me how did you get the bolts torqued??I had a hell of a time,the torque is so low you want to be right..those alum.heads only take 13 to 18 ft lbs.of torque. and I thought I was going to blow up the truck trying to get the egr.pipe loose.any way Idid it all myself with only my old ladysyelling to help me..HaHa. I matched all this up to a set of Ravin z-55. cat back what a nice sound. Then to top all this off,a drunk totaled it while I was working. any way good luck and keep safe.Oh yes WLF the torque is 13 to18 ft lbs....Oldgray
Old Sep 30, 2003 | 06:08 PM
GearHead_1's Avatar
Oh yeah, I didn't have to cut any bolts and didn't figure in the alcohol factor. That explains it.
Old Oct 1, 2003 | 05:37 PM
OLDGRAY's Avatar
Hey Gearhead-1 You are right,I didnt figure that, But it was lite beer just the same. My Black lab helped a bunch,Ever try to work on your truck with a120lb dog helping..? fun i tell you. oh well,youll have a nice day Oldgray.........
Old Oct 1, 2003 | 06:11 PM
GearHead_1's Avatar
I haven't tried the big dog but do have experience with a 6 lb. poodle laying on the middle of my chest while I'm on the creeper.
Old Oct 19, 2003 | 07:13 PM
WLF's Avatar
WLF
Hay guys, thanks for all the help and info. Have had a lot of projects lately with the new transmission and electric fan install. This weekend was the last camping trip of the year so I just may try to get this done next week.
Again, thanks.
