Ok I give up!!!!
Old Sep 23, 2003 | 10:21 PM
belly boat's Avatar
Account Suspended For Inappropriate For Using Email System To Send Inappropriate Messages
Ok I give up!!!!
I have a 2001 f-150 4.6 auto tranny 4x4 ext cab. It runs rough at a idle and in gear. It has new plugs, fuel filter ,oil filter, air filter. Cleaned injectors, Maf sensore, O2 sensors cleaned look great. I geuss I have to bring it to the dealer unless you guys have some suggestions?????
Old Sep 23, 2003 | 10:43 PM
arrbilly's Avatar
IAC valve?
Old Sep 24, 2003 | 09:07 AM
Linetest's Avatar
How rough? I have a new S'crew with a 5.4l. It shakes a bit at idle, in and out of gear also. In other words, I don't have to look at the tach to know its running, cause it shakes a bit. My '99 S'cab with a 5.4 had the same shake. so I consider it "normal". The dealer said it "could" be the K&N FIPK with the '99. So I gave up on having it looked at further.
Old Sep 24, 2003 | 09:24 AM
Home skillet's Avatar
Can also be caused by "grounded" motor mounts.
When the mounts are grounded, all the engine vibrations will be transfered to the frame and up to the pass. compartment.
Old Sep 24, 2003 | 10:03 AM
flafonman's Avatar
Don't give up, read the following.
Won't Idle 4.6
