Engine
Old Jul 22, 2003 | 10:41 PM
D.E.H's Avatar
Question Engine
I have a 98' F150with a 4.6 and the engine light is on,I had the code's pulled and the computer is telling me that it is runing to lean on bank's one and two. If there is anybody that has had this problem, I would like to know what you did to correct it. Thanks for your help
Old Jul 23, 2003 | 08:08 AM
fieldthis's Avatar
From a friend of mine that works at a Ford dealer, the two most common problems that would cause a system too lean code are vacuum leak or dirty MAF sensor.
From this board, most people seem to find a problem with the vacuum connection on the back side of the throttle body adapter. This connects to your PCV valve. That would be the first thing I would check.
Or you can do a search on this site using P0171 or P0174 and it should bring up quite a few threads about this same topic.
Good luck
Rob
Old Aug 12, 2003 | 11:43 PM
lejuan70's Avatar
Lean banks
I agree that you should check for vacuum leaks and the MAF sensor, however I found the on my 98 4.2 after 8 months of searching and replacing sensor after sensor it was the feul pump itself that was defective. I have not had a problem since then. I would check for vacuum leaks first, because to fuel pump is around $100
