Engine Swap
Old Jul 21, 2003 | 12:34 AM
rwilluweit's Avatar
Engine Swap 5.0 - 5.8
Hello. I am new to the boards. First off ill tell you what i have,
1990 F-150 XLT Lariat 5.0 Standard Cab, Longbed
2000 XLT Extended Cab 6 1/2' Bed 5.4 <<< Two of them
On the 1990, I am redoing it. it is ready for new paint (old paint came off grr) Engine also needs replaced, leaked oil.
My Question: is the 5.0 in the 90 interchangeable with the 5.8 (351)? or are the motor mounts different?
Old Jul 21, 2003 | 08:53 AM
vavet5308's Avatar
Even if the motor mounts are the same, they are 13 years old. If you're thinking of swapping in a different engine, go ahead and replace the motor mounts at the same time. They are probably only $15-20 each.
Old Jul 21, 2003 | 04:08 PM
rwilluweit's Avatar
i know they need to be replaced, i need to know if they are in the same location.
Old Jul 22, 2003 | 12:10 AM
rwilluweit's Avatar
does anyone know?
Old Jul 22, 2003 | 12:30 AM
Tailgator's Avatar
The 302 & 351W uses the same motor mounts & are in the same location. The trans.& flywheel will also interchange. But, the 351W has a taller deck on the block which means the engine is about 2" wider. You will have to use 351W mounting brackets for the A/C,P/S,A/P, & Alt. Also, iF your using the MPFI system you need the PCM for the 351W as well.
Old Jul 22, 2003 | 01:49 AM
rwilluweit's Avatar
im sorry but whats the pcm, is that the computer??
The 5.8 in the 90-93 or whatever the span of that generation, was a 351w? did they not have the C or M anymore?
Old Jul 22, 2003 | 02:05 AM
Tailgator's Avatar
The PCM is the main Engine/Trans. computer. There are 3 different 351 engines---A 351M(modified) 351C(cleveland) & the 351W(windsor). The windsor is the most commond 351 & is the one that would be the easiest to swap, since the late model version of them came with the MPFI system. Yes, the '90-'93 would be the windsor engine.
Old Jul 22, 2003 | 03:19 AM
rwilluweit's Avatar
thanks, would this be more trouble than its worth? cause i gotta get a new engine in there either way.
Old Jul 22, 2003 | 10:52 PM
rwilluweit's Avatar
i think im gonna try this
