P0401 OBD code PROBLEMS...
Old Jul 9, 2003 | 10:41 AM
m_lacien's Avatar
97 4.6 v8 windsor 118,000 miles
OBD code = p0401 exhaust flow
replaced DPFE sensor...code still present
replaced EGR valve...code still present
cleaned vacuum hoses....code still present
any thoughts would be appreciated
Old Jul 9, 2003 | 10:57 AM
AjRagno's Avatar
Search the Engine forum under P0401 and you'll find a few posts about cleaning the throttle body EGR ports. That is most likely the issue here.
Also: Did you clear the code from the computer's memory after each part was replaced, only to find the code came back soon after?
Old Jul 9, 2003 | 11:05 AM
m_lacien's Avatar
Thank you AjRagno
for your quick response. I had the code cleared each time at Autozone...
