What tools do you use for...
If you want to buy a kit that has the tuff already together for simplicity reason, you can go with one from Standard Abrasives.
http://www.sa-motorsports.com/diyport.htm
They have the individual parts, as well as kits large enough to do heads. It is not required to do a kit, you just need the abrasives in increasing order to port something out.
Summit sells these, as well as a few other places online.
You can use a die grinder or if you don't have a large enough compressor for this, I guess you could try something like a RotoZip tool, or a dremel tool. I don't think that is the prefered tool for use. The grinder needs to be able to do ~ 18,000 RPM for porting.
See if Neal posts back what he uses. The mfgr specific kit is not a required, just the correct steps with the correct grit.
Good luck
Steve
Good luck
Steve
Thanks again, Steve. I might just splurge for that kit...looks neat.
I'll prob. be picking up a TB the week after next and by that time, I'll let all you know what I decide to do. I still have to get the Magnaflow exhaust upgrade!
Right On!
-Matt
Right On!
-Matt
