Favorite Oil Filter???
Old Jun 30, 2003 | 05:29 PM
Bart&Red's Avatar
What brand do y'all prefer to use and why?
I realize some people will be rabid fans of one brand or another, but there is a big difference in filter design between the major manufacturers.
I'd always just grabbed a Fram until I read some really disturbing stuff about their quality the other day.
Old Jun 30, 2003 | 05:37 PM
LARIAT1's Avatar
From: INDIANA,.....USA " Where more than Corn grows in Indiana"!!!
I use PureONE by Purolator. They also make MotorCraft Oil Filters for Ford. All the hardware, but the paper media. Its sent to them by a ventor that Ford uses.
Lariat#1
Old Jun 30, 2003 | 05:43 PM
lilricky2's Avatar
Purolator One minimum, usually Mobile One. There was an excellent thread on this website a year or so ago on filters. Thats why I'll probably never buy another Fram. The opinions on this are going to be wide and varied, but I personally don't mind a few extra bucks two or three times a year for what I consider to be quality stuff.
Rick
Old Jun 30, 2003 | 05:47 PM
Bart&Red's Avatar
Yeah, Purolator also makes Quaker State and PowerFlo.
How about K&N or Amsoil's filter? Anyone got experience with them?
Old Jun 30, 2003 | 05:50 PM
Bart&Red's Avatar
Here's a great thread I just read up on.
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Sounds like Purolator and Mobile One are the best "run over to Wal-Mart and grab one" brands.
Old Jun 30, 2003 | 09:30 PM
Labnerd's Avatar
Oil filters are rated by their "Beta Ratio" in regards to efficiency. While I can post the numbers, they are not really relevant as the test criteria is vague at best. There is no spec on viscosity, temperature, flow rate, pressure, just to name a few. I can tell you that the Purolator and Motorcraft will filter the most and smallest particle size in a single pass. The K&N and Wix are on the other end of the scale filtering the least. So it sounds like the Purolator and Motorcraft are the best-right? Maybe, maybe not. While they filter more and smaller particles, they also flow less oil. The Wix and K&N will flow more oil but filter less. All others are in between. So it's up to you, better filtration or more oil flow.
Old Jun 30, 2003 | 10:28 PM
mf150's Avatar
easy solution..when racing, use a K&N and when cruising around town, use a Motorcraft FL-820S. You won't have any long term damage from either filter, so it's splitting hairs.
Old Jul 1, 2003 | 12:06 AM
01 XLT Sport's Avatar
Motorcraft for me...
Old Jul 1, 2003 | 12:09 AM
rocketir's Avatar
pure one oil filter and mobil one 5-30 oil. Every 5K.
Jes
Old Jul 1, 2003 | 09:35 AM
msparks's Avatar
I've used the Amsoil filter in the F150 application. It seemed to work well for me. Before I put my by-pass on, went over a year without changing the filter(oops ) Anyhow, now I have a by-pass system on.
If you are really concerned about how clean the oil is staying, take a close look at by-pass filters. My oil stay's very clean now becuase the filter that I have on can keep the oil cleaner than when if comes out of the quart jug from new.
Also, I have a super large FF filter on my truck that hold Almost 2 quarts. So flow is not a problem. It's hard for me to understand why they put such small filters on our trucks?
Old Jul 1, 2003 | 10:25 AM
Texcowboy9's Avatar
It's a matter of opinion of course, but I use the Motorcraft 820S in both of my vehicles.
Old Jul 1, 2003 | 11:07 AM
LE PEW's Avatar
As of late I've been using Purolator Pur1 filters with either Mobil One or Castrol GTX 5w/30 oil. No lubrication related problems but I cant blame that on the filter.
Old Jul 1, 2003 | 11:47 AM
Trever Adamo's Avatar
after reading that i'm soing with the motorcraft from now on and to say my truck has olny 2200 on it but i did chage the oil and i did use a pureone so i'm all good but knowing that the motorcraft is the same and it is less i'm going to go with that one now
Old Jul 1, 2003 | 01:06 PM
Schmidt452's Avatar
So anyone besides me run a bosh oil filters. I have for years with no problems.
Old Jul 1, 2003 | 05:28 PM
Neal's Avatar
Cool
HI!... I've been running the K&N HP-2010 oil filter for the last 3 oil changes and I have had no problems.
