oil on spark plug thread bad???
Old Apr 23, 2003 | 01:44 PM
hyflyer78's Avatar
hey guys i have a 97 f150 4.6 sc 4x4 and for a while everytime i take the passenger side first spark plug out theres been oil on the threads but NOT the spark plug itself. the truck runs good and doesnt smoke. should i be worried about this or is there a simple fix. the truck has 79,000 and runs perfect. do i have a problem????
Old Apr 23, 2003 | 03:10 PM
JMC's Avatar
JMC
25 Year Member
Is there a trace of oil on the plug boot? Or on the engine leading to the plug cavity? It may have spilled when the oil was changed/topped up. What colour is the electrode? Check out http://www.mztech.fsnet.co.uk/workshop/wrk_plugs.html
do you see your plug in the picture?
JMC
Old Apr 23, 2003 | 06:39 PM
hcmq's Avatar
It sounds like a valve cover gasket leak to me.
Old Apr 23, 2003 | 06:46 PM
hyflyer78's Avatar
the plugs are burning right no oil on the plug just aroung the threads. i cant see that its leaking from the valve cover but im not ase certified so it may be leaking but where would it leak from that you could not see or trace.
Old Apr 23, 2003 | 07:08 PM
JMC's Avatar
JMC
25 Year Member
78,
The oil filler tube is just in fornt of and to the left of the plug hole. It doesn't take much oil to drip out and cause the plug hole to have a bit of oil. If the engine was spitting oil enough to slip past a plug then you would feel it in the way the engine performs. With a clean cloth wipe the filler tube and then the valve cover and you will most likely see traces of oil on the rag.
JMC
