Diesel In Gas Engine
Old Apr 8, 2003 | 04:38 PM
hcmq's Avatar
10-4 on that green! But hey it is worth a shot!
Old Apr 9, 2003 | 01:08 PM
gopher's Avatar
Don't go hog wild on the green pump idea. Mobil uses a green color on their regular gasoline, unlike just about every other retailer in the US. Weird, but true...
Old Apr 9, 2003 | 01:22 PM
2001 F-150 SPORT's Avatar
Stupid question, but what would happen if you put regular gas in a diesel engine? Would it just pop?
Old Apr 9, 2003 | 01:41 PM
Green_98's Avatar
i imagine that it wouldnt run due to the lack of spark plugs.
Old Apr 9, 2003 | 02:12 PM
crashz's Avatar
Trust me on this, diesels run great on gasoline. Real fast, real strong, until the motor seizes in about 45 seconds! Pistons melt, injection pumps seize, injectors shatter and heads / blocks crack.
How do I know you may ask? My ex-girlfriend (10 years ago) filled the tank with premium on my 83 GMC 6.2L diesel. Thought she was doing me a favor, and she did. I had to swap the motor for a 454
Old Apr 10, 2003 | 02:26 AM
KYFordFreak's Avatar
crashz
Sorry man but she did do a favor if she blew your 6.2 diesel. IMO, those are one worthless diesel engine. I wish I had 5 cents for everyone of those that were swapped out for a gas engine.
Old Apr 10, 2003 | 08:30 AM
Chopper's Avatar
It happens....... I was travelling across a "isolated" area in Montana one Sunday last summer and was getting low on gas. Found an out of the way country store with pumps. Pulled in and put in $20.00 dollars worth of "gas." Drove over to the store and payed...... Truck started running crappy as I was pulling out on to the highway. Made it about a mile down the road and it was running really, really bad........ Turned around and limped back to the store. Checked the pump, and on the backside, noticed marking in felt pen that said diesel! Sh 1 t .............. Manage to siphon the diesel out through the vent line for the tank after much goofing around. Filled the tank with gas, and off I went, sorta. Blew up one cat on the LHS. likely got plugged.
When I got talking to the people that ran the store, they made the comment....... "Jeez, the last guy that did that couldn't even get his truck started, we had to get it towed!" Never mind what I said..........
Anyway, if you haven't noticed any ill effects by now, you're likely ok......
Old Apr 11, 2003 | 01:40 PM
crashz's Avatar
Aw come on KYFordFreak. You don't think 165 HP and 250 ft-lbs of blazing raw power is awesome in a 1-ton!
Hehe, yeah that thing was a boat anchor. Had no business being in a truck of that size. What a huge difference in performance when I swapped in the 454.
Old Apr 11, 2003 | 01:45 PM
crashz's Avatar
Actually - I think I over shot the HP. I think it was only like 135 HP!
Old Apr 11, 2003 | 02:31 PM
Old Timer's Avatar
Hi Lariet
Sorry for your headaches. I dont have answer. Hopefully your engine will be ok.
Union 76 here...diesel #2 handle is green. Plus big label. Nozzle appears to be same size as unleaded nozzel. These pumps (for cars/lt. trucks) are on island along with unleaded pumps. Its also a truck stop (separate islands) for the big rigs.
As i recall, ive seen other brands here with "green handles" but dont know if thats a standard color used everywhere...or just some brands?
Good luck...OT
Old Apr 11, 2003 | 02:56 PM
F150Europe's Avatar
Talking
Green handles: 95/98 Unleaded
Yellow handles: 98 premium plus
Orange/Red: Diesel
Old Apr 11, 2003 | 03:02 PM
grinomyte's Avatar
wow you would be messed up in los angeles, diesal all around. Worse yet i would be all screwed up over there Hey europe hows the truck doin? Last time you were having some bs happening and was considering a lightning. Still on?
Old Apr 11, 2003 | 08:13 PM
Fords4ever's Avatar
Talking
Flying J is a TRUCK STOP......all the rigs around you should have tipped you off.
Old Apr 11, 2003 | 10:39 PM
2fords's Avatar
LMAO!!!!! I'm qualified becaused I've done bone head things too! Welcome to the boneheads doing bonehead things club!!!
Thats right up there with not seeing the ladys room sign and walking into the lady's room and looking for the urinal.
Sorry!
Old Apr 12, 2003 | 06:52 PM
medic's Avatar
I'm gonna agree with most of the others. A diesel nozzle should NOT fit into a gas vehicle. I used to work in a gas station / truck stop prior to becoming a paramedic. There are 2 sizes of diesel nozzles - both of these are bigger than an unleaded nozzle and will not fit into gas vehicles from the mid 80's & up. I think this is a requirment in New York.
I have also attempted to put diesel in my truck. I put diesel into ambulances all day so it's a bit of a habit. The only thing that saved me was the bigger nozzle. BTW, the diesel nozzles at this station are yellow.
I would definately contact Flying J's & complain. They have admitted to a problem, considering it happens 3-4 a week. They need to stock larger nozzles for the diesel pumps. They are attempting to save $$$ by using the same nozzles for all applications at your expense. People need to start complaining to the larger corp. person instead of the local manager.
On another note - gas and diesel don't mix unless introduced under high pressure, higher than any consumer gas / diesel pump can provided. This should make cleaning things out a bit easier.
