Regular vs Synthetic Oil
Old Jan 27, 2003 | 11:16 PM
MyFordTruck98's Avatar
Question Regular vs Synthetic Oil
I have been using the Motorcraft 5W30 that Ford says to use but was wondering if synthetic is better. Does the type of oil really matter?
https://www.f150online.com/galleries...TOKEN=37026799
Old Jan 27, 2003 | 11:20 PM
Sorry for the multiple posts. For some reason I can't delete them.
Old Jan 28, 2003 | 12:12 AM
Tiger's Avatar
Synthetic is better. The real question's are do you needit? Do you want it? Are you willing to pay for it? Will you really benefit from it?
I use Mobil 1. I like it. I make mostly short trips. My drive to work is 3.5 miles. That's grueling. Really. I don't see any difference in gas mileage. But it did alleviate some cold weather starting noise (grinding). Mostly it just makes me feel good because I feel I own a great truck and the cost of the changing Mobil 1, 2 times a year is about 50 bucks. Conventional oil would cost me about $$16 bucks a year. For a $34 differential, you bet I use Mobil 1.
This has been hashed through plenty. You could spend countless nights reqding the old threads, just use the search function.
Old Jan 28, 2003 | 01:02 AM
About how much more is synthetic? I pay around 1.50 at wal-mart for the motorcraft oil. Would I have to use a different oil filter than the motorcraft? I also have a grinding noise too.
Old Jan 28, 2003 | 03:59 AM
mf150's Avatar
Mobile 1 can be bought for around $4 a qrt. It lasts at least 5,000 mi. or/ 6 months. Motorcraft filters are synthetic compatable. My father runs Mobile 1 10W-30 and a Motorcraft FL-820S. I run Redline 5W-30 and an FL-820S.
Old Jan 28, 2003 | 07:11 PM
Texcowboy9's Avatar
If you intend to go much beyond 3k on oil change, I would suggest the synthetic. I use Royal Purple 5W30 and change at 5 - 6k depending on how much highway driving I have done. I have been using Mobil 1 filters but intend to change to Motorcraft next change because of what I have read on this and another board. I feel the synthetic gives much better protection on startup. For a lot more info on oil and filter try www.bobistheoilguy.com.
Old Jan 28, 2003 | 10:54 PM
Thanks a lot guys! Anybody know anything about any detrimental effects of changing over to synthetic or any precautions to take?
Old Jan 29, 2003 | 04:33 AM
mf150's Avatar
There aren't any detrimental effects caused by synthetic oils. The only thing I could forsee hapening is that a change to synthetics could exscaserbate (sp.?) a pre-existing oil leak.
If you want a long relationship with your vehicle, both synthetics and dino oil are wonderful as long as you change them on a regular basis. The reaason I switched to synthetic is because i want that extra piece of mind and I do a lot of city driving.
sorry, my spelling is horrible.
