Lightning Mass Air Meter
Old Dec 31, 2002 | 01:39 PM
EM02supercrew's Avatar
Just curious if any of you have added this upgrade to your 5.4?
I have heard that alot of Mustang guys are using this mas air meter to gain more power as it will trick the computer in reading a different volt amout than is actually there to add more fuel!!!!
Let me know if any of you have done this mod and what gains your have seen and where you purchased this mod?-
EM
Old Dec 31, 2002 | 02:50 PM
Neal's Avatar
Cool
HI!... 1ST off you will need a custom programmed chip (SUPERCHIP) to run a LIGHTNING's 90mm MAF. The "L's" MAF is calibrated for 42LB injectors. The 5.4 has 19LB injectors. If you just bolt up the 90mm MAF without getting a tune you will scew up your AIR/FUEL ratio's "BIGTIME"!!!!!!! Anyone that says they just bolt it on and go, is quite frankly a major FOOL! I have a 90mm MAF for my 5.4 and it still does'nt make as much power as with my stock 80mm MAF. I have to get to a dyno and have a 'TUNE" done to get it set up right for my AIR/FUEL ratio's.
Old Dec 31, 2002 | 07:07 PM
GearHead_1's Avatar
I did this but like Neal said, it isn't as simple as just bolting a new MAF on. I had to upgrade the injectors, fuel pump (255 l.p.h.) to support the injectors and have the SuperChip calibrated for these changes. All this for maybe 12 horses or so. I wouldn't suggest you do this unless you've run out of some of the other mods (i.e. electric fans, underdrive pulleys, headers etc.). If you are to that point with your mods then by all means go for it.
Old Jan 2, 2003 | 01:36 PM
Thanks for the info guys! Much appreciated
I will think about ading this mod once I have my underdrive pulleys, and a few extra bones around for those injectors and the custom chip!
I appreciate the heart ache that ya saved!
But when you did buys thsoe did you go directly to FORD???-
EM
Old Jan 2, 2003 | 04:00 PM
GearHead_1's Avatar
I bought the Ford Injectors and MAF. I purchased them through Mike Troyer. You may find them a little cheaper but you won't have the other benefits that Mike brings to the table and I checked, you won't save that much. He also sold me the fuel pump though I don't remember the brand now. Of course he can handle the reburn of your SuperChip. I would recommend calling him when your ready.
Old Jan 2, 2003 | 06:03 PM
Neal's Avatar
Cool
HI!.... I also bought my 90mm MAF from MIKE TROYER. I also got my 190lph fuel pump, superchip, LT headers, high flow CATS, MAGNAFLOW mufflers, tips, s/s tubing, filter, lotek 3 way guage pod, pinnion snubber from him. I'll be getting a PLASMA BOOSTER from him very soon also.
Old Jan 2, 2003 | 07:34 PM
GearHead_1's Avatar
Neal,
Plasma Ignition is on my list this month also. We've got quite a few of the same mods though I've got the shorty JBA's and not LT's. Mine won't go as fast. I'm pulling a few more pounds with the 4X4.
Old Jan 3, 2003 | 02:12 PM
Sweet soundslike you guys are on your way to some fast f-150's!
How do I get ahold of this Mike guy? OSunds like he does some good stuff if oyu have gone back to him a few times!
ANd with his chips, are they actually custom to your mods or is it a mass produced programmer???-
EM
Old Jan 3, 2003 | 03:48 PM
GearHead_1's Avatar
I hope Mike doesn't mind me posting his information for him. This is the info he puts in his signature. He sells SuperChip and I think he works directly with them to develop some of his custom burns. Don't hold me to this as I'm not 100%.
Mike Troyer
Performance Products, Inc.
Truck & SUV Performance Specialists
National Distributor of JDM Engineering Performance Parts for Lightnings
National Distributor of Magnaflow
(540) 862-9515
Email: MikePerformance@cs.com
Online Superchip ordering system: F150Online Superchip Ordering System
National F-150 Online Rally Event Organizer
New website under construction: TroyerPerformance.com
