Help!!!!!!
Old Aug 3, 2002 | 06:08 PM
Joni Nitro's Avatar
Unhappy Help!!!!!!
I just changed tranny fluid with Royalpurple, and now there is fluid all under my truck. I seems to be coming from the rear seal on the tranny's output shaft. Did I add to much (3.75)qts. See my post in Transmision's for more details. Help!!!!!!
Old Aug 4, 2002 | 01:57 AM
WrongdayJ's Avatar
Hmm. Tough question. Sorry, but I can't help on this subject.
Please let us know what you find out, OK?
Later,
WrongdayJ
Old Aug 4, 2002 | 02:33 AM
01 XLT Sport's Avatar
Orignally posted by Talleywacker:
Tools needed:
Tranny fluid/oil pump (autozone, oriely, napa, pepboys)
440 channel locks
oil catch pan
4 qrts of new mercon rated ATF
1. remove fill plug
2. put something under tranny to catch old fluid
3. remove drain plug
4. let oil drain out completely
5. screw in drain plug and tighten real good
6. use Tranny Fluid Pump from oriely or autozone
7. pump new fluid into fill
8. you want fluid to be full to the fill hole, it will leak out letting you know it's full
9. tighten fill plug.
Done!
Total time: 15 Minutes
As you can see from his instructions you wouldn't have been able to put to much fluid in your tranny fill hole because it would have just leaked out.
Old Aug 4, 2002 | 08:50 AM
Joni Nitro's Avatar
I forgot to metion that my truck was on a lift and was kinda tilted back, twards the rear, and I believe that I didnt get all the old fluid out.
Old Aug 4, 2002 | 01:04 PM
Talleywacker's Avatar
Suspended For Violation of Vendor Rules
to put to much fluid in your tranny fill hole because it would have just leaked out. [/B]
Unless he had the truck off of center, which he did.... like tilted back, then it will be too full. Then it would find a way to force itself out if it was tooo full. However if the guy only put in 3.75 qts. it should be fine.
One thing to remember, royal purple atf is real thin also... it could be you have a small leak on the yoke seal (if i remember right)
Have you ever ran your truck through high water?... This could be the cause of it leaking.
Old Aug 4, 2002 | 04:55 PM
Joni Nitro's Avatar
Talley
I do think it is the seal that is leaking, but I think that be having to much pressure in the trans, it blew the seal. Have you replaced this seal. I am pretty sure I will be doing this soon. And I only put in the 3.75qts, but I dont think I got it all out.
Old Aug 4, 2002 | 05:15 PM
Originally posted by Joni Nitro
Talley
NO, and THANK GOD!!!
If this problem came up without warranty I suppose I'd have to (nobody but me works on my truck).
Never done it but shouldn't be too hard. At least I know what is involved with doing this; removing driveshaft etc...
Old Aug 4, 2002 | 08:03 PM
Joni Nitro's Avatar
With 33K, an extended warranty and a lowered suspension, is there anyway that it could be covered if I played dumb. Maybe not the honest thing but dealers rip people off daily?
