O2 sensor and cat question
Old Jul 6, 2002 | 06:18 PM
Joni Nitro's Avatar
Is there a off-road/Hi-flow x or h pipe setup for the 6. What would happen if you were to remove the rear set of cats. I know there is are O2 sensors on there, but could a MIL eliminator work, or how about cutting a hole in the replacement pipe and weld a nut on there and thread the O2 sensor back in. How would this effect the CPU. Just curious, have been working on a custom exhaust setup and would like a little extra room under there.
Old Jul 7, 2002 | 12:27 AM
WrongdayJ's Avatar
The second set of cats/O2 sensors are used by the OBD-II system to veryify that the 1st pass EEC-V A/F corrections were successful, and to ensure that the EEC hasn't allowed an adaptive trim correction to let the engine release amounts of pollutants beyond the programmed limits.
SO-
Unless you axe the 1st set of cats, too, as in a full open off-road exhaust system, then you must run both sets together.
Hope this helps. . .
Old Jul 7, 2002 | 12:35 AM
Talleywacker's Avatar
Suspended For Violation of Vendor Rules
Listen to wrongdayJ on this one...
Old Jul 7, 2002 | 11:08 AM
Joni Nitro's Avatar
I probably will try to jus keep them in tact, seeing as I still have 50k on my warranty and dont want to get into deep. Thanks
