oil drian
Old Mar 13, 2002 | 06:21 PM
samiam513's Avatar
oil drian
i ahev a 97 f150 4x2. In the past it was taken to the oil lub express for oul changes bu ttoday i decided to do it myself. Where is the drain plug? the manual only has the add oil plug. I htink i found it ubt it has 4x2 stamped beside it. Is this it?
Old Mar 13, 2002 | 06:43 PM
AjRagno's Avatar
Find the oil pan at the bottom of the engine and you'll be fine.
You don't have to worry too much about removing the wrong drain plug.
The transmission doesn't have one so the engine oil is the only drain plug down there. The drain plug is on the passenger side of the engine and on the side of the pan rather than the bottom.
Old Mar 13, 2002 | 06:53 PM
TubaMan's Avatar
it's on the passenger's side if i remember correctly, and i think it's a 14MM bolt.
wait till u do the oil fitler, that one is a real pain in the butt. the 45 degree angle insures you will get oil running down your arm i perfer one of the snake wrenches to take it off
Old Mar 14, 2002 | 11:18 AM
2wise4aGM's Avatar
Wink
It's a 15mm bolt! Sorry TubaMan, it's just that I did a change yesterday and had to look for mine (it was on the ratchet I had in my hand! ). As for the oil running down your arm- just consider it "elbow grease"!
Old Mar 14, 2002 | 08:03 PM
crazedf1's Avatar
mine is 15 as well. or you can look at it as not needing any lotion
Old Mar 15, 2002 | 07:50 AM
RWillieK's Avatar
You could just punch a hole in the bottom like I do - let it run into the pan, and then take it off......use a staight bladed screw driver and a hammer - doesn't take much... saves the greasy elbow, and driveway....
Robbie
Old Mar 15, 2002 | 10:52 AM
crazedf1's Avatar
well thats a way to get it done i usally just turn it slow and let the oil drain while im turning the fliter.
Old Mar 18, 2002 | 04:55 PM
WOLVERINE's Avatar
Yeah, everytime I go to pull the oil filter off, the hot oil runs down my arm and get all over my clothes. Looks like they could've found a better location for the filter does'nt it? Plus I have to wipe the oil off of my frame right under the filter too. What a messy job!
Old Mar 20, 2002 | 12:19 PM
LeanNCut's Avatar
Robbie
Tried that with a Honda Accord, drove around for 3 miles leaving a trail.. (Still ran) Then the EPA (Environmental Protection Agency) boys/girls showed up with smiley faces..
Old Mar 20, 2002 | 12:22 PM
crazedf1's Avatar
i know it was a honda, but were you trying to burn it up
