Just installed Cool-Collar
Just installed the Cool-Collar oil filter heat sink. Checked oil temp on dip stick with IR thermometer before and after installation (engine at normal operating temp).
Oil temp before install(10 mi. driving) - 214 F
Oil temp after install (10 mi. driving) - 197 F
17 degree drop in oil temp for - $18.95 from jcwhitney.com - not bad.
It's a finned, aluminum collar that fits over the oil filter and is secured with a stainless steel clamp. I had to trim off 1 finn width to fit the Motorcraft FL-400S filter - but it was no problem.
Fits perfectly and it even protects the filter from stones, etc. For $19 bucks and shipping it's a cheap mod that actually helps cool the engine oil down. And it looks cool, too!
Here is the link to J.C. Whitney's catalog page.
There are a lot of articles about this product on the net. Do a search on "Cool-Collar" if you want to read more about it.
http://www.jcwhitney.com/product.jht...D=5217&BQ=jcw2
Here some more info on the Cool-Collar install and the manufacturer's test data.
http://www.pelicanparts.com/techarti...ool_collar.htm
Talleywacker,
When you get it you'll need to cut off one fin to get a perfect fit on the Motorcraft filter. If you use a filter with a slightly larger diameter (like Mobil 1) no trimming is required. The instructions said it was scored to easily remove 2 fins, but I couldn't see the scores so I used a hacksaw. Aluminum is soft so it was no big effort.
Originally posted by Corpsie
How does this affect your oil system when your car isn't up to operating temp and it's cold outside? Wouldn't this cause oil to flow poorly through your filter?
My $0.02
It works the same way a remote oil cooler works, but obvioulsy not to the same extent. The heat sink works the same as those used in electronics to cool hot devices in stereo, computers, power supplies, etc. Another factor is the air flow over the heat sink fins while on (or off) the road.
You have to read the supporting articles and then make up your own mind. All I can say is that it showed the 17 degree decrease on my engine.
No, there's not a major temp drop in the oil filter. The oil is continuously flowing through the filter with some heat being removed as it passes through. The overall effect is a drop in temperature for all the oil. It doesn't get cold in the filter and then get dumped back to the supply. The heat transfer takes place as the oil circulates. It's just like your radiator - the cooling is spread out over the entire coolant (it's an average since it's moving). That's the best I can explain it.
