general mods
Good choice!
Hey it will cost you, I did not want to spend any money at first, but after reading these posts, I coulndt resist, I spent a $1000 to get my truck at the preformanvce level that it is at know,
SUPERCHIP - AIR FORCE 1 - Flomasters Single in Dual Out.
this All equals=
Good gas milage and shifting, with increease in power safely, Good throtel response, and breathing , great sound, and looks.
My best .02 I can give you, oh you might want to put in some subs for the tunes it allways is good.
Oh and yes, none of thease will, void any warrenties, or anyting.
Im 99.9% positve.
this All equals=
Im 99.9% positve.
Im pretty sure the af1 and the chip will void your warranty. The chip i know for sure will. you will have to take it out if you bring your truck in for servicing. As for the af1 im also pretty sure it will void your warranty as well. put the stock breather on befor you bring it in for servicing. As for the exhaust im not sure if it will void your warranty but from ford i guess its possible.
The only perf mod i have though is a drop in k&n filter and synthetic oil which realy doesn't add up to jack for performance but i believe its better for the engin.
Good Luck
Syeth
Good Luck
Syeth
not true..
I have talked to ford and Mike T the chip guy, It is not leagal for them to void it, it is not a big enough of a mod to void the warrenty, Ill bet money on it, and the intake cant, it uses the same wireing and sensors, its no diiferent than putting in a new K&N filter!! Same thing witht the Exhaust. About having to remove the chip for service, its true you do have to removi it.
There is too many guys with that set up to have it be true.
you do not "change" the chip. you "add" a chip. by the way...superchip, FIPK, and any kind of exhaust does not void your warranty. the " Magnuson-Moss act " as posted above is what keeps it from being void. but now lets say your aftermarket muffler rusts and gets holes or whatever. that is not going to be under warranty. you get the idea. The main reason you remove the chip is not to hide it from the dealers. (eventhough some do for this reason) you are sapposed to take the chip out for when your dealer does a diagnostic check of your comp. they get the right numbers. check out the computerchip forum and ask mike. he will let you know all the details. just my .02
Arom
Arom
yup
The only way an aftermarket part can void your warrenty is if it is found to be the cause of said problem. Such as, you get a chip, chip screws up badly and shorts out your computer. The computer will not be covered under warrenty.*
*This is JUST an example and I have NEVER heard of this happening.
You get the general idea.
You probably don't have to worry about damaging your engine with a FIPK and a chip but the Magnuson-Moss act is not a silver bullet that repels Ford with impunity.
Ford does have an official policy of denying warranty claims for both aftermarket chips and FIPK's, so don't expect a warm response from your dealer if you have any engine or transmission problems.
When people speak about the Magnuson-Moss act , they make it sound as though all you have to do is say the magic phrase and Ford will fix your problems but it's not that simple. When you purchased your truck, you signed away your right to sue Ford and settle instead for the dispute resolution board. Although the laws state the "Ford" must prove that your mods caused the problems, it will be "you" trying to prove a built/design problem while Ford points the finger at you.
The chip and the FIPK are well worth the money and each can be removed in a few minutes if you need service so don't worry about them. If you get a cat-back exhaust on the other hand and you have burnt valves or cats, you will pay the bill.
Basically when it comes to mods and warranty, whatever you change now becomes your responsibility.
If you add a shift kit: Void the transmission warranty.
If you add a supercharger: Void the engine warranty.
If you add a suspension lift: Void the suspension warranty.
There are chips that let you run normal octane (87octane for those of us near sea level)
There are chips that require that you use higher octane.
There are "flip chips" which let you select a less agressive calibration if you need to run normal octane and back to a more agressive calibration when you refill with higher octane.
BTW: a supercharger may void your trans warranty.
