got a few problems, does anyone else have them?
Old Dec 31, 2001 | 05:20 PM
crazedf1's Avatar
well ive got the 2000 w/ the five speed and like many the 2-3rd shift i sometimes get alittle grind, i also have a lillte difficulty putting it in gear everyonce in a while. ALSO the clutch pedal is loose feeling.
anyone have this???
thanks
Old Dec 31, 2001 | 05:42 PM
hades281's Avatar
Yeah I had the 2-3 upshift grind; Ford rebuilt the transmission for that. It still doesn't like going into first sometimes - double clutching helps.
Also as far as the clutch feeling "loose" - there is supposed to be like an inch or so of "free-play" or so from the top of the petal to where it begins engaging the clutch... is this what you mean by loose? If so that's normal.
Old Dec 31, 2001 | 06:19 PM
crazedf1's Avatar
no loose i mean that the pedal has about an inch or so that will move freely. then after that inch or so the clutch is acutlly being pused in. when i got it it had that inch or so that you would push in the pedal and now it does not have it. sorry for the weird description the best i can do now(getting ready for the new year in 7 hours now )
Old Dec 31, 2001 | 07:45 PM
PimpinF-150's Avatar
i was having 1st-2nd and 2nd-3rd gear grinds, nothing a new clutch and rebuilding the tranny didnt cure hehehehe
Joe
Old Dec 31, 2001 | 09:43 PM
hades281's Avatar
If you're saying that the "freeplay" is *gone* from the clutch pedal, I think it means one of 2 things: either the self-adjuster on the clutch pedal is not working (adjusting) properly or the clutch is worn and it's time for new? I might be wrong about this but I think that's what it means. How many miles?
Old Jan 2, 2002 | 11:37 AM
crazedf1's Avatar
only 26K once i have some time off im going to put it in the shop and they can deal with it and eat the cost
Old Jan 29, 2002 | 04:30 AM
jabtay's Avatar
I have had my transmission worked on twice already because the syncronizers keep going out. first it was between first and second now its between third and forth. if i didnt like shifting gears so much i would get an automatic
