3.5 EcoBoost Shudder and hesitation
Old 08-17-2018, 01:47 PM
F150PlatinumWY's Avatar
Truck: 2013 F-150 Platinum 3.5L EcoBoost 4x4 with 95k miles
Condition 1: When at steady throttle and speeds ranging from 30mph - 70+mph, if I roll onto the throttle gently, I get a momentary shudder from the motor as it revs up. This happens for less than a few seconds but is easily duplicable. Happens every time I ease into the throttle. If I stomp on it, there's no shudder.
Condition 2: At highway speeds, when I go to overtake someone, and put the coals to it, as I pass through 80mph and roughly 3500-4500rpm, the truck starts to jump as if it is missing.
Condition 3: Randomly, when I come to a stop and then go to accelerate directly after, the truck will delay acceleration, then hit hard. Like a whiplash effect.....
Variables: I have changed fuel brands, and have tested in tow/haul mode, 2x4, 4x4H and 4x4A drive modes. Hot and cold temperatures and high and low elevations.
I hope that all of these are connected to the same issue...but any help figuring it out would be greatly appreciated.
Old 08-17-2018, 03:40 PM
glc is offline
Replace your spark plugs. Ecoboost plugs are only good for about 40k till they start to miss. Gap is critical.
If the plugs are new and you know for a fact that none of them are cracked or damaged in any way, you may need one or more coils.
The following users liked this post:
Old 08-17-2018, 03:51 PM
Thank you,
I'll have that done and reply back with the outcome.
Old 07-12-2021, 09:35 PM
Michelrick89's Avatar
Follow up
Im having similar issues to your post, did you change the spark plugs and have any success?!
Originally Posted by F150PlatinumWY
Thank you,
Old 04-23-2022, 11:01 AM
Smknjoe78's Avatar
Mine had the bump when gassing it from a dead stop, turned out to be the "F150 bump" This is an easy fix, you need to buy the part from a dealer or even on Amazon. Here is a video that should help. This is the one piece drive shaft but it is very similar with the two piece shaft.
. Here is the part from Amazon. Ford KIT Drive Shaft Boot Repair...
Amazon Amazon
. Joseph
Old 04-22-2023, 09:00 AM
Squirrel1226's Avatar
Shudder at gentle throttle
[QUOTE=F150PlatinumWY;5239747]Truck: 2013 F-150 Platinum 3.5L EcoBoost 4x4 with 95k miles
Did you figure it out?? I have the same problem as condition 1!!
Quick Reply: 3.5 EcoBoost Shudder and hesitation
