2014 f150 3.7L NOT EcoBoost
Old 06-12-2018, 08:39 PM
Jmla0713's Avatar
There is a noise coming from under the hood that SOUNDS like a belt but they all look fine. The tensioner pulley and water pump have both been replaced. It happens when I start the truck and quiets when I get to 5th but doesnt happen ALL the time. When the motor gets warmed up, the sound goes away. But again, it's not every time I start the truck. 2 people have said the alternator but when I have taken it to get checked, the readings come back fine. Suggestions?
Old 06-12-2018, 08:58 PM
I betcha it is the alternator making that noise.
Old 06-12-2018, 09:01 PM
Jmla0713's Avatar
What in the alternator could be making the noise if the readings are coming back fine? Also, can rebuilding it fix the problem?
Old 06-12-2018, 10:24 PM
Roadie's Avatar
Bearing. If it is like the old alternators that I have taken apart, the rear alt bearing is just a bushing.
Old 06-13-2018, 05:33 AM
Jmla0713's Avatar
Thanks! We will try that!
Quick Reply: 2014 f150 3.7L NOT EcoBoost
