Clutch and rear main seal replacement on 2003 f150 with 4.2L motor
Old Mar 11, 2018 | 11:49 AM
Farmerdan81's Avatar
Exclamation Clutch and rear main seal replacement on 2003 f150 with 4.2L motor
I'm a pretty mechanically inclined person. I'm replacing the clutch, flywheel, slave cylinder, and rear main seal in my 2003 f150 with a 4.2L motor. Do I have to drop the oil pan when I replace the rear main seal??? And would it be a good idea to replace the u-joints in the driveline at the same time as clutch replacement??? It is a 2wd truck. Any help would be greatly appreciated
Old Mar 11, 2018 | 12:04 PM
Oil pan does not have to be dropped. Make sure you also replace the pilot bearing. New u-joints wouldn't hurt as long as the driveshaft is out, especially if they are original.
Old Mar 11, 2018 | 02:03 PM
Yep, I agree with glc. It won't hurt.
