351
Old Feb 23, 2001 | 11:58 PM
IAMCA's Avatar
Post 351
I'm thinking of buying a 2k F-150 with th V6 stick in it. Because of my financial situation right now, I can't go bigger. But I've been scheming about after I have paid this truck off, to put a 351 in it. Will it fit? Do I need a new tranny, and such? I've got a few years to get the plans straight, but I thought I'd ask now.
Old Feb 24, 2001 | 09:41 AM
eph1fifty's Avatar
Post
I've seen some 97+ F150's with 351 V8 in it. The people usually go with carbs. But those are show trucks. Some even install solid axles in front. I think you would save money if you sold your truck and bought a used one with a V8. I'm not sure but the 5.4 isn't a 351???? But one thing for sure your 5-speed mazda transmission will NOT fit the 5.4!!! You will need to switch tranny too.
Old Feb 24, 2001 | 01:03 PM
Talleywacker's Avatar
Suspended For Violation of Vendor Rules
Post
5.4 w/ manual in a reg cab f150...
umm, you'd have some traction problems in 1st
Old Feb 24, 2001 | 01:46 PM
BROTHERDAVE's Avatar
25 Year Member
Post
why not just buy a 5.4 now? if it is for financial reasons just wait till you have to have custom parts made for the swap. i know of no one who makes a kit for dropping a 351 (5.8 liters) into a 97 up f-150.
Old Feb 25, 2001 | 12:22 AM
IAMCA's Avatar
Post
5.4 is smaller than the 351. I think the 351 works out to be about 5.9 L or so. I was thinking of putting a 5.4 in it and a manual from a super-duty (gotta have the stick). That oughta handel the power, right?
Old Feb 27, 2001 | 08:43 AM
Mav07's Avatar
Post
I've got an answer for the why not 5.4. The 5.4 is a modular type engine with EFI. The 5.8, being carbeurated is a heck of alot cheaper to build and put in, and it produces more power to boot. I have a friend that works for Ford racing and he told me he could build me a 5.8 for about $1300 while a 5.4 new would be almost $2000. Thats not including tranny switch and custom work. The other reason is because the 5.8 is not really a 5.8. Its more like a 289 bored over to a 351. That reduces the cost some more and makes it alot easier to finance.
1997 Ford F-150
4.2 L V-6
Thrush Turbo Tube catback exhaust
K&N Air Filter
Window Tint
Pioneer 7000R CD player
2 Rockford Fosgate DVC HX2 10's
Rockford Fosgate 500a Amp
Lund bug shield
Vent Shade Vent Visors
GTS headlight blackouts
Bedliner
Chrome Toolbox
3" Body Lift
305/70R16 ProComp Muds
16x10 Eagle 589
Chrome Westin Nerf Bars
4.10 Precision Gears
Custom Key racing stripes down both sides thanx to some a**hole in the HS Parking lot.
My WebPage
Old Feb 27, 2001 | 03:46 PM
25 Year Member
Post
hey mav07 i also live in the houston area, were are you going to pass inspection with a carbarated 351 in a 97 truck. impossible to bore a 289 to a 351. in the 5.0 world there are people who sell kits to make a 302 into a 347. custom crank and piston alon would be more than $1300. the 351 block is different than the 302, 289 block.
i really dont think you understand all the time, expense involved in such a swap. start off at the gas tank, what are you going to do with the in-tank electric fuel pump, way too much pressure for a carbarator, does it bolt up to the trans and by the way, the computer runs the trans so what about that? wiring harness? which oil pan will fit the 97 engine bay? exhaust mods as this is not a direct bolt in? custom a/c brakets, the list goes on.
Old Feb 27, 2001 | 03:59 PM
smcconaghie's Avatar
Post
For those that don't already know, the 5.4L engine is actually 329cid. Not sure if the block is the same or not.
'99 Ford F-150 Lariat Supercab 4x4
5.4L Triton V-8
Wedgewood Blue
MODS TO COME:
K&N FIPK
Gibson Swept Side Exhaust
Hard Tonneau Cover
Old Feb 27, 2001 | 06:36 PM
dirt bike dave's Avatar
Post
Mav and others - the 289, 302, 351 and 400 all share the same 4" bore. The 351W is a stroked (not bored) 289, and the longer stroke requires a taller block. Other versions of the 351 (the C and the M) have further differences from the 289/302 in block and head design. The 351M is more closely related to the old 400 'small' block and has an even taller block than the 351W.
Those custom 347 stroker versions of the 302 are also generally over-bored to 4.060" to get up to 347. Expensive but pretty cool if you want to stick with a 302 size block.
The 351W, M, or C can be tuned to put out more power than a stock 5.4, but they are older technology and when hopped up they tend to get much worse fuel mileage and probably pollute a lot more.
Old Mar 4, 2001 | 08:29 PM
DaveH's Avatar
Post
A 351 is a 5.8L, a 5.4L is a 330, as a 350 is a 5.7L. a 302 is a 5.0L.
2001 F-150 5.4L trition,
Regular cab with 8' bed
XLT with Black Clearcoat
4x4 3.55 limited slip
factory cab steps
class III tow package
Factory ordered: 12/5
recieved: 2/22
