oil pan removal
Old Feb 9, 2001 | 03:56 PM
Andi's Avatar
Angry oil pan removal
can someone tell me hoe to get the oil pan off of my 92 F-150.. Have an inline 300 6.Have raised the motor a dozen times but still can't get enough clearence to reach in and remove the pick-up screen, much less slide the pan out once thats done.I am getting really frustrated because this job should not be taking this long or be this complicated.
Old Feb 9, 2001 | 07:26 PM
Y2K 7700 4x4's Avatar
Post
(sorry -- my suggestion was too simplistic)
[This message has been edited by Y2K 7700 4x4 (edited 02-09-2001).]
Old Feb 9, 2001 | 09:33 PM
Nomopar4me's Avatar
Post
stupid question, but why are you removing the pan? If you need to just replace the gasket, you can do it without taking out the pan. If you must remove the pan, you will need a cherry picker and MAY need to take off the upper intake for that tiny bit more clearance. also, loosen the tranny mount. and remove the driveshaft(s). This should get you a bit more room to get your *****-beaters in there. Good luck.
Old Feb 10, 2001 | 12:02 AM
Andi's Avatar
Angry
removing the oil pan because there is no other way to change the oil pump
Old Feb 10, 2001 | 01:04 AM
Andi's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Y2K 7700 4x4:
</font>
why is that and what was it?
Old Feb 10, 2001 | 06:22 PM
Post
Well -- I merely suggested that you lower the truck onto a jackstand that was supporting the harmonic balancer.
But after posting it, I re-read that you had already hoisted it -- so the suggestion would have looked stupid given the history of steps already taken.
