Recall Work and Leak Damage
Old May 26, 2000 | 07:47 AM
1GoodCop's Avatar
Unhappy Recall Work and Leak Damage
I have a 97' 4.2 6cyl. On June 5th it's going in for the recall leak of the coolant. I told the tech that it's only a small puddle in the mornings, but he said and I've read here that it may have damaged the motor. HOW DO I KNOW?...IF I NEED a new one. hOW CAN i CHECK AND MAKE SURE THEY AREN'T GOING TO PUSH ME THROUGH, AND HAVE IT BREAK DOWN THE ROAD?...thanks.....the truck has 81,000.
Old May 26, 2000 | 11:39 AM
1GoodCop's Avatar
Unhappy
Please Help, work is going to be done soon!!!
Black 97' F-150 XLT Flareside, 4.2 6 CYL.
Deflecta-Shield lighted visor
ExTang Tonneau cover, GTS hood and window deflectors
Manik 4x4 pushbar, Hyper-Blye Headlights, Lund Shadow Cowl
265-75r-16 Pirelli Scorpions, Tinted Windows
Huge Stereo!, Ford factory alarm and entry
Old May 27, 2000 | 11:11 AM
Frank S's Avatar
Post
Try to see if the tech will make a note of the leak on the invoice. If your engine fails later you might be able to get them to cover it since it was a design flaw.
Old May 27, 2000 | 08:43 PM
Shifter's Avatar
Post
One way to protect yourself is, before they do the work, take a sample of your engine oil and have it tested in a lab to see if there is any anti-freeze in it. Might cost you $20 or so.
If you want, take the sample at the dealership doing the work so a service rep sees where the oil came from and that you're not someone to be jerked around with.
Black 2000 SC short-box XLT. 4.2V-6, 5-speed, 3.55 limited-slip. CD, remote entry, factory side steps, FORD box liner.
My third F-series: '73 F-100 Custom 240-cube 3-speed, '98 F-150 XL-SC 4.2 5-speed, and '00 F-150 XLT-SC 4.2 5-speed. GREAT trucks!
Old May 27, 2000 | 11:34 PM
1GoodCop's Avatar
Post
Thanks Frank and Shifter, will do both, hopefully, just HOPE it isn't to late.
Old May 28, 2000 | 01:12 AM
Bubbadewsky's Avatar
Talking
If you have antifreeze in your oil you will know it, because with even a small amount it will cause the engine to lock up. For some reason it causes piston pins to sieze.
2000 F-150, XLT, SC, 5.4, 4X4, 355 LS, ORP, Black/Silver, class III, single CD, sliding glass, med. gray, keyless, elect. shift, engine date 8-18-99, Superchip. '93 Harley Fatboy Black & tons of chrome
Old Jun 9, 2000 | 04:08 PM
crash1's Avatar
Post
Ok guys,
If you have coolant in the oil, it will form a thick, milky substance.
The engine will only lock if coolant enters the cylinders because you cannot compress a liquid. The coolant will, however decrease the effectiveness of the oil, increases wear and may cause bearings to seize. Either way, it's not a good thing.
I have never seen a leak dump a couple of gallons of coolant into the crankcase. It USUALLY does not get that far.
'98 4.6 5-speed
BRING US YOUR TUNDRA!
Where we started.
After a facelift.
Latest MOD!
trixters-playground@excite.com
F-150online Photo Album
crash@f150fanatic.com
MAGNACHARGER
ALLEN
[This message has been edited by crash1 (edited 06-09-2000).]
