04+ 4.2 in a 97 f150??
Old Sep 23, 2010 | 11:22 AM
mrfatride's Avatar
I did a search and did not really find any info. Basicly wondering if I could use a 04+ 4.2 in my 97 f150. I figure I would have to swap over the intake manifolds since it appears the newer trucks were drive by wire. Any info would be great since I can find 04+ much cheaper than 97-03 motors. Thanks!!
Old Sep 24, 2010 | 12:01 PM
Raptor05121's Avatar
The block is the same, but the electronic part is whats going to screw you over. If your 97 needs an engine, I would personally look for a 4.6L V8. They are a lot more common than the sixes
Old Sep 25, 2010 | 08:43 AM
mrfatride's Avatar
wouldnt I need a new ecu/wiring/etc to swap in a 4.6?
Old Sep 25, 2010 | 11:24 AM
illness95's Avatar
ima take a stab in the dark and say , youd prolly need to completely rewire your truck along with a new computer yada yada yada.. but if you were just wondering on using the short block then im almost certain they are the same ..
Old Sep 25, 2010 | 03:28 PM
the 97-98 trucks were very basic. in 99 Ford intoduced the PATS system in which almost everything was computer controlled. the ECU from 99-08 is no way compatible with a 97-98 truck.
Old Sep 26, 2010 | 09:49 PM
mrfatride's Avatar
well it looks like my 4.2 has a dead cylinder so i am just going to find a used 4.2 in a recycle center. will the 4.2 econoline v6s from 97-03 work as well?
Old Sep 26, 2010 | 11:53 PM
yes
Old Sep 27, 2010 | 06:24 PM
mrfatride's Avatar
awesome i found a 4.2 out of an 02 econoline with low mileage that i am going to try and pick up on friday!
