plugs!!
plugs!!
Got my truck a couple days ago and decided to change the plugs,wires ETC. It is a 99 f-150 4.2 140,000 miles 5 speed. when i pulled the plugs i was shocked they had a little white marker spot on the tip of the plug!!!! 140,000 miles with the factory plugs, i could'nt believe it,and they looked fine also. they was gapped like crazy but the truck ran fine. the only problem i have had is i changed all the vacum lines....
If you do replace the plugs..don't use Bosch. 99.9% of the time the motor will run rough with these plugs..even if gapped properly. Stick with Motorcraft, Autolite or Denso iridiums. For some reason these motors are very picky.
I have 131,000 on original plugs and it still runs great.
Did you have any problems getting the plugs out, I am wanting to change mine myself but am a bit nervous from all of the stories I have read.
GOD Bless,
jerry
GOD Bless,
jerry
The only one that I found was a PITA was the one closest to the firewall on the pass. side. Unless you have a few swivel heads for your sockets prolly best approach is to take off the front pass wheel and access it from the wheel-well.
The horror stories you are reading are for the 5.4 3 valve V8. Our V-6 plugs are a piece of cake as long as you can reach them.
So as far as it being an aluminum block there is no precautions I would need to take to make sure that nothing breaks or strips
thx, one more question, I have never had an aluminum block before, is there actually something I need to know that is different from the a steel block
