plugs!!
Old Mar 26, 2010 | 10:32 PM
I thought the head and block on the OBS F150's were fully cast iron?
Old Mar 26, 2010 | 10:38 PM
8wingman4's Avatar
http://www.ford-trucks.com/specs/2000_f150_1.html
Old Mar 27, 2010 | 10:17 AM
Nossir, iron block and aluminum heads.
Old Mar 28, 2010 | 07:54 PM
bullfrog's Avatar
When pulling plugs on aluminum heads, you need to follow two rules:
1. Thou shalt not pull plugs with a hot/warm engine.
The engine should be stone-cold because hot aluminum-heads + hot steel-plugs = stripped threads)
2. Thou shalt not put in plugs without first applying copper anti-seize lubricant to the spark-plugs' threads.
This helps avoid stripped threads as well and reduces the chance of suffering later on if you violate rule #1.
Old Mar 29, 2010 | 10:37 AM
NOT necessary if you use Motorcraft plugs, the threads are nickel-plated. You MAY use it in the V-6, but do NOT use it in the 4 thread V-8 heads.
Old May 2, 2010 | 12:42 PM
ExTex's Avatar
I recommend that, if you do feel the need to use anti-seize, use aluminum-base rather than copper! Copper in aluminum can cause problems. Actually, though, with nickle-plated threads, you don't need to use anti-seize at all.
Old May 6, 2010 | 08:46 AM
If you use antiseize, use NICKEL antiseize.
