Engine is missing, missing my engine.
Old Mar 4, 2010 | 06:58 PM
Nimbus09's Avatar
First things first. I would like to thank all of the contributors on this site. Without y'all (yup, I a' Texan) I would not have been able to repair my truck to its current condition. I have had the p0171 & 0174 codes, completed the gasket and isolator bolt repairs, replaced egr valve, dpfe sensor, cleaned egr ports and intakes etc....truck is no longer throwing codes, but between 1200-1800 rpm's the engine misses or "bucks". I can hear what sounds like an intermittent chirp when I listen to the engine after starting, I am leaning towards a vacuum leak, which I cannot locate for the life of me. I am also considering a coil pack issue, I accidently disconnected a coolant hose during the aforementioned repairs and antifreeze got into the coil pack wire holes. I dried out thoroughly, or at least I thought I did, but am not sure if I could have damaged a coil. Any suggestions would be greatly appreciated, I have become obsessed with fixing this. Truck has 153,000 miles and has been driven fairly passively. Thanks Again.
P.
Old Mar 4, 2010 | 09:46 PM
I'd replace the coil pack... whether I'd be COP, CP, or DIST types of ignition, none of them like water. Why?! Think about it... electricity!
Old Mar 4, 2010 | 11:10 PM
Do you have a good set of Motorcraft plugs and wires on it?
Old Mar 4, 2010 | 11:12 PM
Good point...
