98 f150 v6 4.2 check engine light on
Old Feb 3, 2010 | 04:11 PM
indiana_jones's Avatar
ok guys i need your help again, i went to auto zone today and got the codes, they are p0171 and p0300
if i let the truck warm up, sometimes the light flashes
just bought the truck and wanting to get it right
if you need to know anything else let me know, thank you, jim
Old Feb 3, 2010 | 06:41 PM
P0171 is bank 1 (passenger side) too lean, and P0300 is random misfire. It probably needs a tuneup (spark plugs, wires, etc.) but you should check for vacuum leaks. If the engine build date is prior to 1/15/98 your lower intake gaskets may be leaking coolant into the cylinders, and that's a VERY bad thing.
Old Feb 3, 2010 | 07:09 PM
this truck had that hydro lock happen, it had 89,000 miles on it, and they put a jasper motor in it. the truck has 121,000 on it now. the truck was a fleet truck for a goverment hospital, and they had the motor put in. so i should start with the plugs and wires? i checked the milage and im getting 16 mpg, and when im going down the road , it runs good, but not so good when stoped in gear, thanks jim
Old Feb 4, 2010 | 03:57 PM
Another thing to check - remove the coil pack, clean it up real good, and check for carbon tracks and cracks.
Old Feb 4, 2010 | 08:18 PM
hey GLC thanks, we have a big snow storm moving in tomorrow so i put the truck in the garage, and im going to check the stuff that you said to. and my ford dealer had to order the plug wires and if they come in tomorrow i will do the plugs, and wires. i will let you know how it go's , jim
Old Feb 13, 2010 | 02:07 PM
GENE DABNEY's Avatar
Mine stayed on for a year and then went out
