Synthetic vs. Conventional
Old Dec 18, 2009 | 06:41 PM
brazzeal15's Avatar
Ive run 5w20 Full Syn my last two oil changes and first oil change was conventional 5w20. Im not noticing any gain in power or cleanliness of the oil at my 3000 mile changes. Should I continue to pay out the butt for good full syn or just go back to conventional?
Old Dec 18, 2009 | 06:46 PM
shotgunz's Avatar
It's really simple. Put whatever oil meets the manufacturer's specifications and makes you happy.
For 09-10's Motorcraft 5w-20 blend at Walmart is pretty inexpensive.
Old Dec 18, 2009 | 06:49 PM
Damon@tirerack's Avatar
Former Sponsor
Ford recommends Motorcraft synth blend. If it's good enough for Ford, I'm cool with it too.
Old Dec 18, 2009 | 06:53 PM
brazzeal15's Avatar
Gracias. I do get free oil from the ford dealership...
Old Dec 18, 2009 | 07:11 PM
shotgunz's Avatar
Then it's a no-brainer...
Old Dec 18, 2009 | 07:52 PM
daves03's Avatar
I use full syn 5-20 and pay 34dollars all together at walmart this includes my filter. I used to pay double that at the parts store and as far as the stealership is concerned i have only been there once and that was to buy some spark plugs.
Old Dec 18, 2009 | 08:04 PM
Svets96's Avatar
I also agree just keep the 5 20 semi syn from Ford. Somebody that I know real well told me to run Castrol Edge full syn. and it was like 50 -60 bucks. I thought to myself well at least I know I can go up to or over 4000 miles with the motorcraft. So that is what I had kept in the crank case.
Old Dec 20, 2009 | 11:22 PM
brazzeal15's Avatar
Oh I change every 3000 on the dot. And I run my truck pretty hard. I just wanted to know if Full SYN is really better or just good to sell to idiots that dont even know how to read a dip stick. I worked as a mechanic all through college and I could never tell the difference.
Old Dec 20, 2009 | 11:38 PM
wutecht's Avatar
I run royal purple in my truck its awesome i can definitly feel the hp i only have 2 other modifications a k&n airfilter and a cherry bomb extreme muffler it may be expensive but royal purple and a k&n oild filter means i can go about 6500 miles on on oil change instead of 3000
Old Dec 20, 2009 | 11:40 PM
wutecht's Avatar
You need to make sure there putting synthetic in there i work at walmartdoing oil changes its suppose to be $55 for a sythetic oilchange
Old Dec 21, 2009 | 04:38 PM
ChrisT's Avatar
I think he probably means he just buys the oil and filter at walmart and that's the price, as opposed to paying someone at walmart automotive for an oil change.
Old Dec 21, 2009 | 07:10 PM
Raptor05121's Avatar
once you run synthetic you CANNOT go back to conventional. synthetic oil seats the piston rings differently and if you run conventional then you will get blow-by and your engine will burn oil
Old Dec 21, 2009 | 07:13 PM
Kr619's Avatar
I ran mobil motorcraft and royal purple and i gotta say there was a lil difference with the royal purple but i think thats just my way of thinking to conpensate the money i spend on buying it
Old Dec 21, 2009 | 07:56 PM
Alex_4.2L's Avatar
Rookie question-I heard someone say that once you run synthetic in a vehicle you cant go back to conventional. Is that true?
Old Dec 21, 2009 | 07:57 PM
Alex_4.2L's Avatar
Ok I had this page up for a long time didnt I? lol thanks for the answer
