Problem Codes
Old Sep 14, 2009 | 09:46 PM
tylerbos's Avatar
Problem Codes
Hey guys new to this, just picked a 1998 F150 4.2 V6 159,000 on it. Love the truck so far but it has an idle problem I need help with. Runs Great but if I'm at a light for over a couple of minutes it starts running real rough, if I put it in nuetral it smoothes out just like that without even touching the gas. I have codes P0171, P0174, and P1506. I know to check for the vaccum leaks and I ohm checked my IAC and it checked out. I thinking of changing the intake gasket, just because of all the trouble I have heard abouth these gaskets. Is this a job that can be done in a day? I am not new to engines, but I havent worked on too many newer model motors. Is there something I should be checking before gaskets and leaks? Any help would be greatly appreciated.
Old Nov 19, 2009 | 09:03 PM
JAMartinJr75's Avatar
I have the exact same codes that you do on mine. The lean codes have been there a while I believe do to the bad gas mileage, while looking for leaks to fix them, I ended up getting the P1506. I am at a loss right now to on what to do. All the vacuum lines appeared to be ok. I may try pulling off the top half the intake to check under it.
Old Nov 19, 2009 | 10:11 PM
See if you can read the build date on the sticker on the driver's side valve cover. If it's before 1/15/98, get yourself an improved gasket kit - change the upper and lower intake gaskets and the front cover gasket.
Old Nov 20, 2009 | 03:35 PM
I did that back in '03 and the dealer screwd the headgasket replacement up so bad they place a new long block in the truck. I know the intake/injection system though was off the old motor.
Old Dec 19, 2009 | 05:40 PM
moto57's Avatar
Get this fixed?
