Running Lean
Old Apr 1, 2009 | 08:36 PM
coonhound130's Avatar
I found the problem . I was just fooling around under the hood last night and noticed the pcv valve was kinda loose in the grommit , so after calling every parts store within 50 miles and no-one having or can order a new grommit I used some gasket silicon and made it fit again . No more Lean codes and alot better mpg . Yesterday it used a 1/4 tank in less than 40-50 miles , today I got 125 miles to less than a 1/4 pulling a trailer .
Not bad for a truck with 186,000 miles and will still smoke the tires and get sideways .
Thanks for all the advice ...
Old Apr 2, 2009 | 08:07 AM
That will do it. Do you have a Motorcraft PCV valve or an aftermarket?
Old Apr 3, 2009 | 01:35 PM
4.2L_Guy's Avatar
i hope i get 186,000 out of mine without to many troubles
Old Apr 4, 2009 | 09:38 AM
I am not sure what brand it is .
Well fellas bad news , It ran good for a few days and now the problem is back . And when the light comes on gas milleage goes way way down . This is driving me crazy .
Old Apr 4, 2009 | 12:16 PM
Replace the PCV valve with a new Motorcraft.
Old Apr 4, 2009 | 03:01 PM
4.2L_Guy's Avatar
Originally Posted by glc
replace the pcv valve with a new motorcraft.
x2!
Old Apr 4, 2009 | 06:41 PM
Will try that . I am also going to get that exhaust leak fixed that is 3 inches from the cat and 02 sensor .
Old Apr 4, 2009 | 06:54 PM
Where Do I get a Motorcraft one at
Old Apr 4, 2009 | 08:57 PM
Try parts stores. If not, there's always a Ford dealer.
Old Apr 4, 2009 | 10:09 PM
The parts store carry the Fram brand or whatever it is .
Think I will avoid Ford Stealership at all costs . They are the ones who tried to feed me a load of bull***** about the problem being an internal valve inside the plenum
Old Apr 5, 2009 | 02:37 AM
4.2L_Guy's Avatar
not to bad an idea. god i love beer
Old Apr 5, 2009 | 08:08 AM
Frams are KNOWN to cause problems. Much as you despise the dealership, what's the big deal about just buying a part if you have to?
Rockauto.com doesn't stock the Motorcraft.
http://www.car-stuff.com/carparts/fo...tmiev2511.html
EV-251
Old Apr 5, 2009 | 08:46 AM
Oreily can order it for me at $9.49 and have it by Monday . I will just do that .
Old Apr 5, 2009 | 09:17 AM
Good deal.
