Fixing an engine knock...
So a little over a month ago my engine started making a weird noise (pebble in a can type rattle) and i did the whole search thing to find out that it was most likely a knock and how to fix it.
So far I have tried putting 91 in and it seems to go away--confirming my belief that it is in fact a knock.
I then: Cleaned the MAF
Cleaned the TB
Changed all the spark plugs to motorcraft SP504's
Changed all the plug wires
Its a 2003 with 94000 on the motor and even after doing all that it still knocks with 87, not as bad as it did, but it still knocks.
I don't mind switching over to 91 if i absolutely have to but do you guys have any suggestions for getting rid of the knock with 87 octane fuel?
Cleaned the TB
Cool I'll give that a shot. Also, every few weeks it will throw a code P1518, the IMRC stuck open bank 1, and then a day or two later it will go away. Is there a possibility these two issues are related since we believe its the intake system thats causing the knocking?
