Air Bag light on dash???
I have an 04 f-150 heritage and recently installed a cd player. when i was putting in the dash kit i had to remove the trim peice around the radio and when i put it back on and started the truck the airbag light was on. can anybody tell me what i did wrong or how to fix this.
the airbag light on the dash should be blinking for a while then stay solid for a while then repeat. Its actually giving you a code to tell you whats wrong. Go count the blink sequence and post it on here and I can help you better. (example sequence: light flashes 2 times, pauses, then flashes 7 times...It should repeat this sequence about 5 times then go solid)
Once we know the problem we can help you out a bit easier.
I pulled the bezel off twice now to make sure every thing was conected, the light would stay off for a day or ywo then comes back on.
Here is how to fix it on the cheap
you don't have to replace the entire PAD module, you just have to replace one LED. Here is a simple video I made on how to fix it.
http://www.youtube.com/watch?v=LjuoFguv-lY
I had to steal a 10 amp fuse out of my fusebox under the hood to run a power inverter during a hurricane. I made the mistake of starting the truck after the storm had passed without replacing the fuse. The air bag light began flashing. I don't remember how many flashes, then it would stay on even after i replaced the fuse. If the truck senses any interruption in the power to the air bag system it will throw a code and it cannot be cleared except by the "super code reader." After reading a few posts on this site, I decided to do nothing and let it reset itself. It did after about 6 weeks.
My advise it to try to search for air bag codes and make certain that your code was due to a power interruption. Make sure you have a good fuse in the box under the hood. Then bite the bullet and go to the dealer, or wait 6 weeks and pray you don't need the airbag.
Good luck.
Good luck.
Wow.
I tripped the airbag light changing those two burned out AC display bulbs. I guess having to disconnect that pad (it's plugged back in) did that. Darn.
One of these days, I will get around to getting that reset. Been about a year and a half, too.
I wish 6 weeks was the cure...
code 27 only
The video I made is specifically for the "code 27" (2 flashes, pause, 7 flashes).I'm pretty sure this code and step by step video are the same for a handful of year models around 1999 and on the ranger and expedition as well as the F-Series trucks. The truck throws that code out specifically due to that LED in the PAD (passenger airbag deactivation) assembly being out. That lights only purpose is to indicate that the passenger airbag is not on, yet if it goes out the entire airbag system will not deploy in an accident(or so I have read on other F-150 sites). Literally all you have to do is take the PAD assembly out, pop it open and solder another LED where the burnt out one is. You don't even have to remove the old bulb, just use the existing solder to attach the new one. My video tells you exactly what bulb it is, Radio Shack has them in three packs for around $3.00. I can see no reason to take this problem to the dealer and spend upwards of $90.00 or to wait it out and hope it goes away and risk not having your airbags deploy if you find yourself in a collision. It took me literally around 10 minutes to fix the problem and filming it. I tried to make the video as complete and detailed as possible so even if you don't know the difference between the radio volume **** and AC **** you can do it.
But PLEASE, for God's sake, don't ignore or delay on repairing this problem if you do have the code 27 flashing, your safety and the safety of your passengers is well worth the 3 bucks and 15 minutes it will take to correct this issue. Sorry to be so long winded but when people were saying let it be maybe it will fix itself, I had to make a point. Thanks for listening to me, drive safe.
