Air Bag light on dash???
Old Dec 22, 2008 | 05:47 AM
coquinn's Avatar
Originally Posted by 04Heritage4x4
Great how-
to man, but I took mine apart the first time and tripped the magnet on the switch and it worked for a little while then quit.
The bulb may not be completely out so when you tripped it, it decided to work again but maybe a bump in the road changed its mind. Just go get you a replacement bulb and solder it in and it will be fine. I haven't had a single problem with mine since I replaced that bulb.
...and with the 120 someodd dollars I saved doing it myself instead of letting the local dealer try and swindle me into replacing the entire PAD, I bought a remote start/alarm system for my truck.
Hope this helps
Old Dec 22, 2008 | 09:09 PM
04Heritage4x4's Avatar
thanks for the info, ill be changing the bulb this weekend, but does the light go off on its own or do I have to do something.
Old Dec 29, 2008 | 01:48 PM
darrenmc32's Avatar
Mine recently blinking... Does anyone know what airbag code 1-9 means? Any help is appreciated.
Thanks, Darren.
Old Jan 8, 2009 | 09:25 PM
Murray92589's Avatar
I had the 2-7 code. you can re-sauter a new bulb (12volt from what ive read on other forums) to the circuit board inside your P.A.D. switch, or do what i did and go get a new switch from the junkyard for 5 bucks. dont take it to the dealership, they want 80 bucks for a new switch. the junkyard replacement works great in my truck though...
Old Jan 9, 2009 | 08:01 AM
thats exactly what I did, Radio shack didnt have any of the LED bulbs so I got one from the local junk yard and switched the key switch.
