electric fans
Old Oct 13, 2008 | 09:33 AM
Layinbuckfifty's Avatar
electric fans
Hey whats up i just bought a electric fan for my truck i have a 98 with a 4.2L in it and i was wondering what wiring i could do to hook it up cause i was just gonna hook it up to a toggle and run it in the truck but i don't want to forget to turn it on one day and then over heat the motor. But i have seen the block sensors i can get and i thought about that but i'm not sure where those go into on the block. then i have seen those probes that just like slide thru the fins on the radiator but i dunno any suggestions would help.
And another thing my temp guage in the cluster quit working would anybody have any suggestions on what would cause that and how it could be fixxed
Old Oct 14, 2008 | 12:51 AM
97XL's Avatar
Just 1 fan?? better make sure if flows enough CFMs to keep the motor cool. Also you might want to look at getting a fan controller that can handle 2 fans just in case the one you have is not enough. Most of them come with kits that include the temp probe and a wiring diagram. Pretty sure there is a how-to on the site somewhere.
Old Oct 14, 2008 | 12:59 AM
I have done a number of installs, write ups, and wire diagrams posted on this forum, search efans under my screen name for more information.
Sounds like you sending unit on your engine is bad. 97 and 98 they had two sending units so you could try switching the connectors for a minute and see if the gauge starts reading correctly
Old Oct 15, 2008 | 10:45 PM
Where is the sending units at for the temp guage i can't find tem and what does they look like. and i'm wondering if i could hard wire it or would i need a kit
Old Oct 15, 2008 | 11:55 PM
sending units should be on the front of the intake manifold area i think. should be about a diameter of a dime, about 1/2" long and has two wires out of it
Old Oct 20, 2008 | 01:17 AM
momospeedracer's Avatar
Either the wiring is shorted or the temp switch for the gauge cluster is bad.
Anyhow, most fan controller kits out there can't handle anything past 30A and some require you to stick a probe between the radiator fins. I went through a few brands and they all failed on me - either fried or probe kept falling out.
I'm finally using the DIF variable speed controller for my dual fan setup. Works great and uses the stock OEM temperature sensor.
Old Oct 29, 2008 | 05:01 AM
i'm just gonna wire the fan up to my ignition wire that way it kicks on when i start the truck so i don't for get about it. and it stays on till i shut my truck off. But i don't see where the wires would have shorted out i don't know i will trace it down and find out.
Old Oct 29, 2008 | 09:04 AM
dirt bike dave's Avatar
FWIW, I have had a Flex-A-Lite Black Magic universal fan kit on my 4.2 for about 9 years and it has worked flawlessly. It was cheap. I live in a hot climate and it has adequate cfm for a V6, but is way way less than what a lot of guys put on the 5.4.
Install was a bit of a PITA due to the 'universal' nature of the kit.
Back in the day, there was a thread here showing you how to connect the fan to the A/C compressor instead of directly to the ignition. So my fan is activated one of two ways: 1) When the motor gets hot, there is a temp sensor against the radiator with a user adjustable switch; and 2) Whenever the A/C compressor is on, the fan comes on.
Old Oct 29, 2008 | 10:54 PM
dirtrider596979's Avatar
mine is llike the one dirt bike dave is talking about
i actualy have a fan kit for a 87-93 mustang on my 01 5.4, it has one fan and a adjustable temp switch with a probe built in, it even had a spot for a wire from the ac compresor to turn it on whn the ac is on, i had it 9 months no problems. i got mine from a freind but summit sells it for about $135, they also sell the controler separate for about 30$ i think.
Old Oct 29, 2008 | 11:58 PM
I got mine from Summit also, about 9 years ago - I think I paid $160+-. Ordered it online and it was delivered to me within 18 hours, so I've got to give Summit an A+ for service.
Old Oct 30, 2008 | 01:48 AM
Fifty150's Avatar
Single Stage Fan Controller
•180 degree turn-on temperature, turn-off is 170 degrees
• Two probes available, 3/8” NPT water jacket thread-in or push-in radiator fin probe
• 30/40 Amp heavy-duty relay included in kit, necessary if electric fan draws over
10 Amps
• A/C override circuit included
• Designed for dual fans
• Maximum capacity: 25 Amps
Part No.
Description
16738
Single stage controller, push-in radiator fin probe
16739
Single stage controller, 3/8" NPT water jacket thread-in probe
16736
Replacement probe, push-in radiator fin probe
16737
Replacement probe, 3/8" NPT water jacket thread-in probe
Derale Cooling Products
3901 Medford Street
Los Angeles, CA 90063
Tel: (323) 266-3850 | (800) 421-6288 | Fax: (323) 263-3948
info@derale.com
