deciding on V6 or V8? this might help...
#61
that is what america is coming to... people go get other people to do there work... people need to learn to pick there own self's up and go... you no.
furthur more the owner of that tire store must be crazy to hire someone who cant drive a manual
#62
About 20 years ago I owned a Maverick with a 3 on the tree - even back then the kids didn't know how to drive it. Had one at the car wash trying to put it in drive and was wondering where the PRNDL was and why it was making all those grinding noises......asked him WTF he was doing and he said the only manuals he's ever seen had floor shifts. He didn't even notice the clutch pedal.
#63
#64
#65
Uhhhh - do you mean to say you fill the tank, drive 330 miles, and fill it again and it takes 26 gallons? I highly doubt that.
FILL the tank and reset your trip odometer. Next time you get gas, FILL it again. Look at the trip odometer and divide what you see by the number of gallons the pump says you put in.
#66
#67
#68
I'm always amazed to see these poor 4.2L MPG's reports. I average 14-15 mpg and I have a 4.2L, 6" lift, 33" tires and 4.56 LS. (speedometer is calibrated properly). I used to average 18 - 19 when my truck was stock. Guess I'm pretty fortunate. It's also normal for my truck to sit with the same tank of gas for a month or more as I don't drive it all that much. I do realize different elevations, climate, different mods, and gas blends affect MPG's to some extent but dang!
#69
#72
fill the tank drive about 300-350 tank is below the E line take it back and fill up at the same exact pump and its like 25.8 gallons... trust me im not an idiot... like i said my pickup gets 13-14 mpg on a good day. 350 on a good day divided by 25.8 gives you 13.56 now am i right or am i just reading the calculator wrong... im not lieing... i know how to calculate MPG lol
I even put the K&N and exhaust - no improvement.
My brother had a 4.6 Scab. We both drove from the Orlando area to Atlanta. Interstate, 75 MPH or so, both trucks had automatics.
He got 19 MPG both ways - I did not. Side by side his truck would run off and leave mine sitting. Rolling on the highway it was even worse. When I stopped for fuel, my needle was below "E". He still had a little over an 1/8th of a tank.
My next F150 was a SuperCrew with the 5.4. No comparing the power and it got better mileage on the highway. All told, I spent the same amount on gas every week and there is no comparison between the 2 regarding power.
In a regular cab with a standard tranny, the 4.2 is probably pretty peppy feeling. But to say it will blow away a like-configured 4.6 is stupid.
The 1 or 2 MPG improvement (if it exists) will not add up to enough money for me to live with the reduced performance (and thus reduced happiness) of a V6 truck.
An overworked V6 can get less MPG than a V8 that isn't being worked as hard to do the same work...
To each his own, but don't try to make a V6 sound like a Prius. It is in a heavy, non-aerodynamic vehicle - it can only do so good on gas.
Flame suit on !!!!
#73
#74
...I won't turn this into a 4.6 verses 4.2 thread like the other 5.4 verses 4.6 threads we have endured..
I had the 4.2 in my truck before and it was a great engine in a great truck. I wanted something different so I got the 4.6 in the same body style on as a Heritage '04 with 4X4. In stock form the 4.2 would be pretty equal to the truck I have now until I put a load in the back or a trailer on then the difference came out..
The difference is the same degree as a 5.4 versed 4.6 in stock trim. My 4.6 is not very off the mark of a stock 5.4 so it doesn't compare with my old 4.2.
If and when I buy another Ford, it will have a bigger V-8 (I won't say which V-8 because it may be a while before I buy as my '04 has 36,000 miles on it...).
#75
i have first hand proof that they're reliable. my best friend has a 4.6 with now close to 340,000 miles on it. we changed the spark plugs for the FIRST time at 298,000 miles.
those motors are bullet proof.
saying a 4.6 isn't a reliable motor is like saying a 6.0 liter powerstroke is better than a 7.3.
p.s.- i BLOW 4.2s away all the time, with my big *** wide 33's. all i have is a flowmaster muffler performance wise.
