just bought a 97 f150 4.2
Old Jun 23, 2008 | 10:49 PM
wdstone's Avatar
it has the 5 speed. I was wondering what transmissino this is? also how realiable are these motors
Old Jun 23, 2008 | 10:56 PM
Grafix Ink.'s Avatar
your asking now...?
regardless they're are some vin decoders out there that will let you know. search.
also.. 97-98 early production motors are known for hydro locking issues... also search
Old Jun 23, 2008 | 11:14 PM
4.2trimble's Avatar
you will need to make sureyour head gaskets are the new ones or it will be hydro locked~
the transmission is?? E40D?? not sure exactly
Old Jun 23, 2008 | 11:22 PM
The 5 speed manual is the Mazda M5OD-R2. The 97 engines had bad lower manifold gaskets which results in hydrolocked engines.
Old Jun 24, 2008 | 05:24 AM
clubracergt1's Avatar
The timing cover gaskets were a bit of an issue in the 4.2. They would leak coolant into the oil at the bottom of the cover. I haven't seen a whole lot of intake and head gaskets on these engines; and I have been with Ford for just over 10 years.
Old Jun 24, 2008 | 09:36 AM
wdstone's Avatar
truck was just too good of a deal to pass up at the the time but thanks for the info guys.. whats the best way to actually tell if there are new gaskets
Old Jun 24, 2008 | 11:14 AM
scott.joyner24's Avatar
ask the dealer you got it from if its head gaskets were changed.
Old Jun 24, 2008 | 07:23 PM
BlueOvalFitter's Avatar
Exclamation
The head gaskets are not an issue....it's the lower intake gaskets and the timing cover gasket.Read this;
http://forums.treemedia.com/fb/showthread.php?t=224
Old Jun 25, 2008 | 10:53 AM
wdstone's Avatar
guy told me all the gaskets are new. truck also has a 140k miles on it and runs good. the only problem i notice is when i turn on the ac the truck wants to vibrate a bit. is this normal? or what could be causing it
Old Jun 25, 2008 | 11:37 AM
My apologizies BlueOval. I was unaware of the gasket problems for the '97. I was just responding to earlier mentions in the thread to whether the head gasket was new or not. Thanks for the link though, actually learned something today.
Old Jun 25, 2008 | 11:44 AM
Yeah, mine vibrates a bit with the A/C on at idle. It smooths out when you get the rpm's up. A 90 degree V-6 is not naturally balanced like a V-8 or a 60 degree V-6.
Old Jun 25, 2008 | 04:10 PM
wdstone's Avatar
different flywheel help this any?
Old Jun 25, 2008 | 11:19 PM
Raptor05121's Avatar
No no, its natural, mine does that too. It should idle @ 800 rpm, but 750 with A/C on full blast. Like glc said, the 90-deg V6 is imbalanced at low RPMs. Up high shes clean as a whistle!
The 5-speed is the Mazda M5OD trannie, mines got the 3.55 non-LS
Old Jun 26, 2008 | 10:33 PM
wdstone's Avatar
thanks really appreciate it. unfortunatley i have no tachometer in the truck.. guess i dont really need it though
Old Jun 27, 2008 | 01:08 AM
*IF* you have 3.55 gears and 255-70/16 tires, your max reasonable speeds in each gear are:
1st - 30
2nd - 55
3rd - 80
4th will hit the speed limiter (96) before it's wound out.
