Royal Purple
Old Jun 5, 2008 | 03:20 PM
pignjig's Avatar
Originally Posted by Fifty150
American Muscle is one of the best sources on the internet for Royal Purple. Low price, free shipping, and no tax. 6 quarts = $38.94.
Royal Purple's Performance Advantages:
* Greater Wear Protection
* Greatly Extends Oil Drain Intervals
* Superior Corrosion Protection
* Saves Fuel
* Reduces Exhaust Emissions
* Increases Horsepower
* Keeps Engines Clean
* Mates Engine Parts
* API Warranty Approved
* Will Not Harm Seals
* Environmentally Responsible
My 07 holds 7 quarts.
Old Jun 5, 2008 | 05:06 PM
Fifty150's Avatar
I also have an '07 4.2L V6. Mine takes 6 quarts. It even says in the manual to use 6 quarts. I'm sure that since the oil level is in the middle of the dipstick crosshatch with 6 quarts, I could get away with using 5 quarts or even add up to 7 quarts, and the oil level on the dipstick will still be in the crosshatch area. But the manual says 6 quarts, the dealership uses 6 quarts, and that's what I use.
Old Jun 5, 2008 | 05:29 PM
Ben99R1's Avatar
My 99 4.2 always takes 7 quarts. I use RP in the tranny and rear gears. I figure if it has to be in there for so long just use the good stuff. In the motor I use castro high mile 5w 20. I always change it at 5000 miles as per the manuel. Almost 150,000 miles no engine problems at all. Ben
Old Aug 18, 2011 | 02:36 PM
cbga's Avatar
Royal Purple advantage
I have '04 3 valve 5.4, used mobile 1 since first oil change,pushing 160k now. switched to RP 5w-20. Average mileage went from 16.2 mpg to 17.8. Constant engine clicking disappeared and engine response is dramatic. When I changed from mobil 1 , before draining,I added 1 qt. of the rp and drove 500 miles. It removed all the varnish that had built up from the mobile 1. Burnt red color when drained. I am astonished at the differance. All synthetics are not equal!!!!!!!
Old Aug 18, 2011 | 03:36 PM
You do realize that this thread is three years old?
Old Aug 18, 2011 | 03:45 PM
dsq3973's Avatar
At least he used the search function.....
Old Aug 19, 2011 | 09:09 AM
truckerdude's Avatar
its his first post, so either he works for royal purple or is a distributor trying to drum up business. RP is no better than Pennzoil Ultra, Mobile One, or Castrol Edge
go away spammer!!
Old Aug 19, 2011 | 09:19 AM
True.....
Old Aug 19, 2011 | 12:27 PM
4.2xl2001's Avatar
I have always bought the Motorcraft synthetic blend 5W-20 and Motorcraft filter usually right off the shelf in WalMart for around $30 total. I've change it every 4,000 miles since new with 150,000 miles now. The shop that installed my rear open diff. gears used RoyalPurple and it was changed once after 1000 miles on the gears. Now after 50,000 miles it still quietly works...great product and it was recommended!
Old Aug 19, 2011 | 12:38 PM
Fifty150's Avatar
Let's see who can resurrect the oldest thread.
Old Aug 19, 2011 | 12:47 PM
......there was a 11 year old one a couple of months ago....
Could do this one..... https://www.f150online.com/forums/ex...haust-tsb.html
Old Aug 19, 2011 | 01:01 PM
dsq3973's Avatar
It is pretty entertaing when someone digs one of those up especially if it involvles some the older members(RockPick, BlueJay, RollingRock, Raoul) when they first started posting.
Old Aug 19, 2011 | 01:09 PM
If I see anything incriminating I'll delete it. I may earn the title for deleting oldest post.
Old Aug 19, 2011 | 01:13 PM
dsq3973's Avatar
You'er no fun!!!!
Old Aug 19, 2011 | 01:19 PM
timmypstyle's Avatar
Originally Posted by glc
80 bucks...........for about 60 I can get a full service oil change with Mobil 1 EP and a Mobil 1 filter, and I'm in and out in half an hour.
autozone sometimes has sales on mobil1. i got mine yesterday. there deal is 5qts of EP plus EP filter for $35. and the normal price per qt is $9. my receipt says a savings of $22 and some change for the deal.
I usually buy 7qts but end up with a half quart or so. my 04 heritage 4.2L took just over 6, my 08 4.2L takes about 6.5-7.
well use 6. but then after driving, like a few days later, check the level. sometimes it will be lower because after its run it holds some oil in the filter so it will be less in the pan. mine read right in the middle of the crosshatch at 6qts but i added another half so it still has enough after the filter fills up. its just preferrance really tho.
could you tell a difference with the rearend being RP?
yup i posted on one after someone ressurrected it. it was from 1999 lol
