Where in hell is my oil going?
1997 F150 4.2 V6- with 106K miles.
Pulled in to get gas last night. Quickly turned hard into station and noticed my oil light came on and went off pretty quick. Never happend before. Thought I better check the level. OMG!!!! After 4 quarts of Castrol 5W-30, it started to show up on the oil stick. I almost had a heart attack. NEVER has it beed even the slightest bit low. NO oil leaks at least non that drip and show up under truck. All else looks fine. AT fluid, coolant. No smoke from exhaust either. WTF!
he just said there aint any leaks under the truck.
i think someone either pulled a prank on you... but other then that i dont know what to tell you... wow 4 quarts and it only holds 5 1/2. that is really low for just a leak
I know. I 'bout had a COW! Gonna have to check into that. Sounds like it could be serious or I really over looked something. I'll try to report back my findings. may save someone else a worse outcome than mine.
Well the back valve cover and head usally won't show much on the ground, just all over the underneath of the truck, or on the exhaust.Alot of people say no leaks, but never get under the truck to look they just look on the ground after they park it.
should be 5 and a half. thats all mine holds. y would one hold more then others. wow 7.5 qrts... thats alot... either somethin is wrong with my pickup... or yours... do you have the wrong dip stick?
