What oil?
Originally Posted by 04heritage
I don't know about you guys but my truck says 5w-20.
So, normally I use Mobil 5000 5w-20 with a K&n filter.
Originally Posted by faulkincanyon
dont worry about it...if people didnt add new threads..there wouldnt be anything to read
*insert hi-jack here*
Sweet wheels btw, what's the back spacing on those?
thanks im not even sure to tell you the truth...just kind of spur of the moment discision to get them when one of my stock wheels split in half...and they had the wheels in stock so I took them
cool, I've been thinking about some 20's for my truck, but I don't want them to stick out to far, which seems to be the style. Those look good IMO. It's getting tougher to find wheels with the 5x135mm bolt pattern.
Isn't 5W20 like water? They put that thin oil crap on there for gas mileage purposes. Yea you may squeeze a half mile more per gallon (if you lucky) but that runny stuff wont stay on internal parts for long.
i love ford... but im not saying that they know everything... them recomending that oil to me is like me recomending a chevy to you. it means nothing. how cares what they recomend. im stayin with im stayin with 10w 30. next oil change i will go to 5w again though. and prly still stay with motorcraft.
With thicker oil the engine has to work harder just to pump the oil, so you actually get more heat and stress with a thicker oil.
I too used to think that thicker oil gave more protection, but that was before I knew better.
they have but ford also put the 6.0L diesel in there pickups... and they spent millions testing it and they still put it in. obviosly they dnt know what is good. lol im sure they know... but im still gunna go with what i think is best. and what someone might recomend to me.
I use to be ignorant to the fact of using 5W20.I use to build small block Chevy engines,as a hobby mostly,and broke them in with straight 30W oil!Afterwards,ide run 20W50 in them.
Anyway,after lots of research,talking to Ford techs,and Honda techs,i'm convinced 5W20 is just as good or better then other weights.You think Ford spent all that time and money on 5W20 research just to say "use it"? No! They have built their engines with tolerances to meet 5W20 specifications! So,long story short,just follow their recommendations;your engine will thank you for it!
Old habits and ideas die hard. Today's oil and engine technologies have very little resemblance to the old "conventional wisdom". I remember when multi-grade oils first came out - a lot of people refused to believe THAT stuff was right for their engines and still ran single grade, changing grades for different seasons. They also were the same people who believed that oil had to be changed every 1000 miles.
10W30? That has not been a recommended grade in most gas engines for close to 20 years now. Almost everyone went to a 5W or 0W cold spec years ago.
I also remember when the "hot" thing was 10W40 - well, it turned out that it was no good for certain engines because the VI improver was breaking down, and I think it was GM that said NOT to use it, use 10W30 instead. I think this was about 25 or 30 years ago - when catalytic converters and unleaded gas became the norm.
