V6 - How is the power
disagree with the posts here guys. i dont know what you guys use the pickup for but it does NOT have enough power to pull anything... i pulled a 3000 lb trailer into a 35 mph wind and i couldent do more then 65 in 4th gear! on a no wind day it woulda did it better but not very good.
i got the v6 becasue it was my brothers before mine and he gave me a good deal on it...
all it is good for is a cheap set of nice nice wheels and gets good millage if your not hard on it... and it looks good...
thats what i think it is good for... any other time i pull a trailer i will use mom or dads diesel's no matter how heavy it is.
maybe my pickup aint as good as yours... but i no now that there is no way it would pull a 18 foot boat that weighed 7000 lbs or more or whatever without slowing down on every hill i came to... my pickup is a very good pickup to just get you there... other then that it aint no pullin machine at all...
maybe its just casue i am used to pulling stuff with diesel's... if you guys hooked a diesel onto whatever your pulling with your v6... you would never go back to the v6.
not disin any of your v6's
im just sayin that mine will never pull anything ever again. unless its like a empty single wheel 8x8 trailer it would pull that fine... but nothin more then that.
I like the 4.2l V6 mated to the 5 speed with 4.10s. The 1st is like a granny gear... but the gearing evens out to still maintain a reasonable 5th (O/D) still if you do the math.
I hauled closed to 3,000# the other day in the bed, without a problem. It was like nothing to the truck... the only difference was the stopping power... and the sway in the rear end.
But because I've been hauling so much stuff lately, my tires are balding quick, because they are passenger tires, and not load range "E" tires for work vehicles. I guess the tread composite is different... but when these Hankooks bald out to the point it won't pass inspection, I'll get something else... probably some GYs or something... I do like Winston Winners... but I don't think they offer them in "E" rated tires.
I didn't buy mine to haul some thousands of pounds, just a 375lb 400ex and sometimes a 16' trailer with 3 other 400ex's. I have no problem hauling the trailer at 75 through hills that are about 40* inclines.
Originally Posted by Chris04v6
just a message in advanced, any question about the 4.2, or just about damn near anything, ask Manual150.
Id imagine his head is huge from everything he knows.
Its called research. you can do it at Google.com, Yahoo.com, and many others.
Just keep it in perspective - if that's possible in your mind. The 97+ F-150 with a 4.2 V6 is stronger than a lot of older generation trucks with a small V8.
dnt no how old you are but there is no 40 degree hill in the u.s. my dad builds boat ramps... i help my dad and have a share in the business... most boat ramps are 12 percent grade... and your tlakin about a 40 percent grade hill... bull crap... i want to see it. i dout very highly that it is that steep
no way that aint fast enough buddy!!! well it is but in 4th gear!!!! i dnt like rappin the motor that high. and duh it will pull better then any car... i would hope it would anyway lol... anyway thats just me... i wont pull with it anymore... u go ahead and pull with it i dont care lol
I think he said 40 degree, not 40%. Here's a site to compare the two...
http://www.geocities.com/sidestreetluge/grade.html
I also stayed at a Holiday Inn last night
If you think 65 in 4th is high rpm's, you have another think coming. With stock tires and 3.55's, that's right around 3000 rpm - which is this engine's torque vs. horsepower sweet spot. That's the same rpm as running 80 in 5th - don't try to tell me you don't cruise at 80 living out where you do. I just went from Spokane to Fargo on 90 and 94 with my cruise set at 80 most of the way - and got 18 mpg on 85 octane mountain goat ****. The 4.2 was built to *WORK* - at 3000 rpm it's not even starting to break a sweat. It doesn't even start sounding rough till you get it over 4000 rpm and it's safe to run to at LEAST 5000. I've yet to hit the rev limiter and I think I've had it up to about 5200. That was about 80 in THIRD.
Towing? My towing limit is 3500#. The limit is due to the M5OD input shaft limitations and/or the OEM clutch concerns, not the engine limitations, the 4.6's with the M5OD have the same limit. Our trucks have the same rear axle as the 4.6 V8 trucks. The automatic 4.2's (which use the same tranny as the 4.6 and most of the 5.4's) will tow 5000# or so.
wow thanks for that... see im sry i might have sounded dumb there but i have no tach in mine so i dnt no what the rpm's are... it just sounds like it is screaming... o and 04 heritage... i thought u might have meant 40 degree hill... maybe it was my bad on thinkin you meant 40% sry
