cold start high idle
Old Mar 24, 2007 | 12:40 PM
feenster's Avatar
Greetings all,,
a couple issues here on my 2001 f-150 4.2 5sp. man., 1st, on a cold start
after sittting over nite, the initial idle goes way up for about 10 secs. then
drops down to the norm high idle for a cold start. This must be a killer on the on the engine, having all the oil still in the pan. I have replace the IAC
valve to no avail. Now this only happens in the cold weather, say below
40 degrees???, in the summer, it never happens.
2nd. Have a slight odor of coolant after driving, no leaks, no coolant loss,
no apparent visible reason. Have been checking coolant level daily,
and its ok???
Has anyone had these or similar issues?
thanks,
Feenster
Old Mar 24, 2007 | 08:49 PM
torkum's Avatar
Have you cleaned the MAF? If not, that may help.
Old Mar 29, 2007 | 01:08 PM
feenster's Avatar
thanks, do you know what the procedure is to clean the MAF?
Old Mar 29, 2007 | 03:47 PM
Quintin's Avatar
Fast idle on cold start is normal. It helps light the catalytic converters off as soon as possible.
Old Apr 3, 2007 | 08:46 AM
feenster's Avatar
,,,,, this is way above the normal fast idle, which it had when new,,,,
Old Apr 3, 2007 | 04:23 PM
Quintin's Avatar
What's it idling at now as opposed to when it was new? What RPM exactly?
Old Apr 6, 2007 | 04:31 PM
feenster's Avatar
please read the problem again........
