95 4.9L F-150 4x2 coolant issues
Old Oct 13, 2006 | 07:32 AM
CaptainCharles's Avatar
I have been noticing that I am losing anti freeze from somewhere. I have to refill the reservoir once or twice every couple of weeks. I put down a sheet under th truck to see if there is a leak, but there wasn't any leaking out....
Thought I may have a cracked head, but no symptoms of that. The truck was running a little on the upp end of the temp gauge the other day, and now has been running fine the last two days.
Any ideas?
Thanks.
CC
Old Oct 14, 2006 | 10:02 AM
Peacemaker's Avatar
Leaky head gasket?
Old Oct 14, 2006 | 02:32 PM
Garbar's Avatar
i had the same issue with my 94 4.9 it turned out to be the waterpump ' i had a good look under the truck and saw it leaking right under the fan. this is where the pump is ' its attached to the fan just go for a short drive then park it and hop out and see if your leaking from it or not
